Forums >> Revit Building >> Technical Support >> Pad, slab, topo, LOST!!
Sat, Mar 28, 2009 at 6:08:21 AM | Pad, slab, topo, LOST!!
#16
4 Stars: 205 Votes
LOL, you have to have in attention when you delete or change the elevation of the points because if you split the surface the "common points" (between the two surfaces) must have the same elevation, if not, you "Create" that mess...
Edited on: Sat, Mar 28, 2009 at 3:24:44 PM
Mon, Mar 30, 2009 at 4:17:37 PM | Pad, slab, topo, LOST!!
#17
Lilian2009
so i have deleted all contour lines from the imported autocad survey plan. fine,it's all flat. can someone tell me what is the COPY AND EDIT INTERNAL POINTS is about? i'm noticing that another copy of the imported survey plan was created. has this got to do with the phasing thing?
IMAC 3.06GHZ,MACOSX 10.5.6 with WINDOW XP PROF, REVIT ARCH 2009,AUTOCAD 2009,VECTORWORKS 11.0,ARCHICAD 7.0,LEED AP.
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:23 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:01 AM
Topo surface/Building Pad problems b/w Existing and New Construction phases
Sun, Feb 6, 2011 at 12:28:27 AM
Building Pad
Mon, Jul 12, 2010 at 12:30:00 PM
SLAB AND PAD
Wed, Mar 25, 2009 at 10:46:14 PM
Page generation time: 0.2168
