20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> New vs. Existing Contours
WWHub, I am using phases. See my attached images. On one plan I have my existing with my existing phases set up (works great) on the other is my new plan which shows the existing grades (minus the demo'd grades) and the new grades but BOTH show up as dashed lines. I don't know how to differentiate the existing from the new on the same plan
If you don't have full control over your graphic overrides with Phases, perhaps some other override is stronger. I resently tested the differnt overrides and came up with this:
Graphic overrides to Object style:
Weakest override is By Catagory
Then By Phase
Then By Filter
Strongest is By Element
Hope it helps, Sofus
Changing existing and new contour lines |
Tue, Jul 17, 2012 at 9:08:56 AM
Create new and existing topo lines |
Wed, Feb 24, 2010 at 12:11:13 PM
Smoothing contours... |
Tue, Feb 17, 2009 at 8:43:14 AM
printing contours |
Fri, Jul 30, 2010 at 2:19:00 PM
contours |
Mon, Apr 24, 2006 at 5:16:04 AM
