Forums >> Revit Building >> Technical Support >> Room
Wed, Apr 30, 2008 at 4:49:34 PM | Room
#16
Good news .... thanks for the update.  Do you think it was only this?
Thu, May 1, 2008 at 11:11:11 AM | Room
#17
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Well the warnings had a lot to do with it.  But, after I cleared those out and it was still causing issues, I tried it on another machine in the office and it worked fine.  Then, I somehow remembered to check the build on the program.  Then it worked.  So it was a combination adn this was merely the last step in fixing the issue.  The gbXML warnings are something to avoid.
If you need to export gbXML, just save a copy file for exporting.  Rather than getting all your Revit warnings in your working project file.
Denver, CO
Revit Architecture
room bounding not recognizing room separation line [ 1 2 ]
Thu, Aug 18, 2016 at 10:02:14 AM
16
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
ROOM TAG TAGS ONLY HALF OF THE ROOM
Wed, May 6, 2015 at 8:58:21 AM
box around room number on room tags
Sun, Dec 13, 2020 at 9:59:00 AM
Room Problem
Mon, Jan 23, 2012 at 9:09:06 PM
Page generation time: 0.1463
