Forums >> Revit Building >> Technical Support >> mysterious hole in wall
Tue, Feb 5, 2008 at 3:25:51 PM | mysterious hole in wall
#16
archshanna
apparently in phase 2 we have a wall there.  ahhhh thanks!
Tue, Feb 5, 2008 at 3:26:44 PM | mysterious hole in wall
#17
NKramer
4 Stars: 9 Votes
Something similar to this poped up on AUGI last week. Are you useing Revit Arch or Revit Str? By default Revit Str does not show non bearing walls. You would need to turn your visibility setting to "coordination" instead of structural. Then all of the architectural objects will appear, otherwise you just see structral elements. According to Revit only bearing walls are strutural; not that this is actually correct but thats the way that revit thinks.
Alternatly you could have something hidden  in plan or someone could have drawn a shaft. Shafts will penetrate through wall walls, floors, etc from their top to bottom. Sometimes they can be a pain to find if you dont know where (what plane and view) they were drawn. You may be able to find it by selecting everything and filtering in that view.
Otherwise try the yellow lightbulb and see if you have something hidden...
HTHNick
Applying Materials To Cover A Hole
Mon, Mar 10, 2008 at 8:26:30 PM
Curtain wall in wall hole
Tue, Sep 8, 2009 at 7:03:33 PM
cutting a hole in a massed floor/roof
Mon, May 11, 2009 at 7:07:00 AM
Mysterious Notch in Wall
Tue, Dec 14, 2010 at 4:29:42 PM
How to infill a topo hole from plit surface
Fri, Jun 15, 2012 at 9:54:54 AM
Page generation time: 0.4930
