10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Revit materials missing at rendering
38 Posts No Rating |
i have never changed any of the bump settings, not sure what they do. Here is a view of my screens and an image of my rendering is earlier in the thread ...
the bump is what gives your materials it's texture. It's an alpha file that creates depth on the dark shades of it, so a brick bump has black mortar joints and white bricks with black dots on it, so it knows the mortar is deeper then the brick and the dots are surface impurities So the material shows should have black horiztontal slits but otherwise fairly plain texture, does it render with the slits ? if so then your rendering is fine
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
No. Even close up it renders completely smooth.
I suggest moving the bump file to your desktop. re-assign it in your properties so you know the link is true. then to a reigon render, if it works then you know it'll be a path problem. If it still doesn't work you might need to reinstall revit as it'll be an issue with your render engine as apposed to your materials because your material properties are spot on
sorry for double post also check you have the material library pathed up can be checked in the options menu as imagedand/or duplicate it and assign it as a backup addition one off of your network
Very wierd.... must be some problem with the render path....
1 Posts No Rating |
I had a same kind of problem but then I noticed that the jpg file had an ä on its filename. apparently Revit does't recognise other than "english" letters.
9 Posts No Rating |
I have the same problem, I can get my roof to render w/ any preset asphalt roofing material, it will render w/ pattern and color assigned by default but I cannot change the color. System will not update in "render appearance" box.
any clues??
tried an Autodesk tech support, they said there are some issues w/ it and couldnt figure it out either...
Revit Custom Materials Rendering Objects invisble |
Mon, Mar 14, 2011 at 10:42:55 AM
13
My jpeg materials keep missing |
Thu, May 13, 2010 at 7:54:23 AM
Basic Rendering Question: Are .bmp & .tiff images usuable for materials? |
Thu, Oct 26, 2006 at 5:25:40 PM
Purged unused and now all of my materials are missing |
Mon, Oct 28, 2013 at 11:43:17 AM
Missing Materials |
Mon, Oct 27, 2008 at 7:25:38 AM
