Forums >> Revit Building >> Technical Support >> VOID FORM says there is no geometry to cut....
Wed, Jun 18, 2008 at 8:38:59 AM | VOID FORM says there is no geometry to cut....
#16
zabel
Yeah.  Gave it a whirl.
Revit throws up this error message:
Can't make change to Group "1st Floor Window" with more than one instance. To resolve: Ungroup and Group again under a new name. Edit and make change, then change all instances of the original Group to the new Group.
When I ungroup, the void form is apparently not selectable as I tried to select all the elements for the new group...
I also tried throwing a void form into a regular window family in the family editor.  Doesn't work.
Wed, Jun 18, 2008 at 9:54:12 AM | VOID FORM says there is no geometry to cut....
#17
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You might want to think about creating that part as its own generic wall based family. I would make it parametric so you can intelligently adjust what you need to, but I know you can add the voids and whatever else in the family and place it as many times and it will cut.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, Jun 18, 2008 at 10:22:41 AM | VOID FORM says there is no geometry to cut....
#18
zabel
Could you (or anyone else!) walk me through that? That's what I'm after and I can't seem to get it to work.
Edited on: Wed, Jun 18, 2008 at 10:23:20 AM
Wed, Jun 18, 2008 at 10:56:11 AM | VOID FORM says there is no geometry to cut....
#19
brettgoodchild
4 Stars: 17 Votes
First, just try making a new generic model wall based family and place a void in it so it is cutting the wall. Then I would load that into a test project and see if what you did works. If so, I would then I would look at adding Ref. Planes and Labels to make it intelligent.
                             ~ Abraham Lincoln
Wed, Dec 17, 2008 at 12:52:27 PM | VOID FORM says there is no geometry to cut....
#20
IloveSKETCHUP
New to the forum. This thread REALLY helped. The void geometry thing was stumping me. Now.... GOT IT!
Thanks!
void form and cuttng void form
Fri, Jul 9, 2010 at 12:39:02 PM
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Void Form in a Wall Sweep
Wed, Dec 1, 2010 at 6:58:00 AM
VOID form will NOT work! [ 1 2 ]
Mon, Jan 30, 2012 at 3:00:24 PM
22
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:44 AM
Page generation time: 0.7031
