Forums >> Revit Building >> Technical Support >> Trying to create a tricky wall (Revit Architecture 2008)
Mon, Oct 8, 2007 at 4:20:58 PM | Trying to create a tricky wall (Revit Architecture 2008)
rat69
Imagine a rectangular room, CMU walls, metal bar joists, metal deck  with 2 layers of 2" rigid insulation, and the most important part: The roof slopes from one side to the room to the opposite side. The CMU walls continue above the line of the roof (see attached image). I need to insulate some of the rooms (interior face of exterior walls) and the insulation and gypsum should go up until they meet the roof but I don't know how to control the shape of a particular layer of a wall (rigid insulation + gypsum) without affecting the profile of the main wall. Is this possible with Revit?I will really appreciate any help.
Mon, Oct 8, 2007 at 4:30:12 PM | Trying to create a tricky wall (Revit Architecture 2008)
I might try to do this as two walls, one above the other.  Then I would edit the top of the lower wall to the bottom of the roof deck and the bottom of the upper - non-insulated wall to the same line.  I would then hope that join geomery takes care of my block.
Tue, Oct 9, 2007 at 6:13:01 AM | Trying to create a tricky wall (Revit Architecture 2008)
coreed
coreed Avatar
4 Stars: 16 Votes
the (rigid insulation + gypsum) should not be part of your CMU wall. they should be their own furring wall type drawn on the inside of the CMU. then on wall where need you can edit the profile to follow the slope as needed.i am assuming that this Cryingrigid insulation + gypsum) does not go above the roof. then use align and lock to tie the furring to the CMU wall.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Oct 9, 2007 at 6:51:49 AM | Trying to create a tricky wall (Revit Architecture 2008)
I did this too on a similar situation but there are problems with this though.  One is that openings in the wall, like doors and windows, only cut one of the walls.  You have to edit the profile for the other wall.  Another problem is that the line betwwen the masonry wall and the furring is a heavier line that is normally on the outside of your walls but now it is on the inside of your composite wall.
Tue, Oct 9, 2007 at 8:54:22 AM | WWHub
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting WWHub from 2007-10-09 06:51:49
"I did this too on a similar situation but there are problems with this though.  One is that openings in the wall, like doors and windows, only cut one of the walls.  You have to edit the profile for the other wall.  Another problem is that the line betwwen the masonry wall and the furring is a heavier line that is normally on the outside of your walls but now it is on the inside of your composite wall."
using join geometry on the two walls will allow any window or door to cut thru both walls and should take care of the heavy line problem.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Oct 9, 2007 at 10:15:03 AM | coreed
Quoting coreed from 2007-10-09 08:54:22
Really ! .... I've got to try that one.  Thanks
Tue, Oct 9, 2007 at 10:24:16 AM | Trying to create a tricky wall (Revit Architecture 2008)
rat69
WWHub: I tried what you suggested but couldn't attach the lower wall to the bottom of the roof because the roof is smaller (in plan) than the walls. In other words, there is no roof above the walls and the program can't find a boundaru to extend to.
Tue, Oct 9, 2007 at 11:13:10 AM | Trying to create a tricky wall (Revit Architecture 2008)
I didn't say attach, I said edit the profile to the line of the bottom of your deck.  It's the point where your wall would change, isn't it?
Tue, Oct 9, 2007 at 12:09:51 PM | Trying to create a tricky wall (Revit Architecture 2008)
rat69
Tue, Oct 9, 2007 at 12:12:20 PM | Trying to create a tricky wall (Revit Architecture 2008)
rat69
Oops! What was that? I just hit F5.
 Anyway. I will try that (edit the profile) and let you know if it works. Thank you.
Tue, Oct 9, 2007 at 12:17:06 PM | Trying to create a tricky wall (Revit Architecture 2008)
#11
coreed
coreed Avatar
4 Stars: 16 Votes
i don't understand what your are saying. but as long as the wall is not curved, you should be able to edit the profile into any shape and height you want.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Oct 10, 2007 at 10:34:21 AM | Trying to create a tricky wall (Revit Architecture 2008)
#12
LIZARD2806
3.5 Stars: 7 Votes
I agree with Coreed-the best way to do this is to use the "edit profile" tool.  Read the help file on it in Revit and it will explain everything.  I found Revit's help section on this very useful.  Good luck!
**Using Revit Architecture 2009, 2011, and 2012**
Wed, Oct 10, 2007 at 12:15:13 PM | Trying to create a tricky wall (Revit Architecture 2008)
#13
rat69
Coreed, seems to be that there is some confusion about what I wanted (I gave up last night). I'll try to be more explicit.
I wanted to create one (1) wall that have it "all": CMU + insulation + gypsum
I wanted to be able to control the 2 interior layers (insulation + gypsum) height independently of the CMU (By editing the style and unlocking the top constrain of these layers).
I got to this point. What I couldn't do was edit the profile of these 2 layers without afecting the shape of the CMU layer. In other words I needed one wall with a layer (CMU) with a rectangulat shape and the other 2 layers (Insul + Gyp) with a trapezoidal shape (to follow the pitch of the roof).
At the end a created 2 parallel walls (what I didn't want to do) and atached the interior one (insul + gypsum) to the bottom of the roof. Then I use "Join Geometry" to merge both walls (as you suggested) and that clear the opening for my doors and windows. Looks good, but I am using 2 walls  #@#$@#&!!!!
Thanks to all of you
Wed, Oct 10, 2007 at 12:44:37 PM | Trying to create a tricky wall (Revit Architecture 2008)
#14
coreed
coreed Avatar
4 Stars: 16 Votes
i think you will have to use two walls as we talked about and as you did. when you edit the wall profile it affects the whole wall as you founded out. remember to use the align command to lock the two wall together so they move as one.
i know what you are asking, but far as i know you when you unlock the top constrain of the parts of a multi-part wall you can only move them up and down and cannot modify the profile for the individual parts.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Oct 10, 2007 at 1:06:15 PM | Trying to create a tricky wall (Revit Architecture 2008)
#15
LIZARD2806
3.5 Stars: 7 Votes
So this is not what you are trying to do?  (single wall, quick schematic)
Crashes with Architecture 2008
Mon, Oct 22, 2007 at 6:48:44 PM
12
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:43 PM
How to create a new wall/roof type?
Thu, Jun 19, 2008 at 10:15:37 AM
In Revit Architecture 2008 How do I create a construction detail?
Thu, Mar 13, 2008 at 10:04:54 AM
Creating Network Deployments - Service Pack 03 - Revit Architecture Suite 2008
Tue, Dec 4, 2007 at 2:39:09 PM
Page generation time: 2.0855
