Forums >> Community >> The Studio >> Architectural fonts
Search this ThreadSearch this Thread | Page 1 of 3 | 1 | 2 | 3 Next >>
Fri, Feb 11, 2005 at 2:17:10 PM | Architectural fonts
mtropper
I'm looking for the famous ARchitxt font or another decent architecural hand type font. Any recommendations, samples and sources??
Mon, Feb 14, 2005 at 5:01:07 PM | RE: Architectural fonts
Thread Post Kudo! #2
arnosandoval
5 Stars: 3 Votes
Revit, doest not support SHX files, so trying to use the Archtxt font won't work. Revit only supports True type font files. There are a number of websites that you can go to ckeck out fonts and pruchase. http://store.adobe.com/type/main.html www.fonts-online.com www.lineotypes.com http://www.philsfonts.com/otlist.html A good font to use is GraphiteŽ Std Regular, another is Handsf Single. Attached is the ttf file for handsf Single. Try it out if you like.
Tue, Feb 15, 2005 at 10:26:19 PM | RE: Architectural fonts
mtropper
Thanks Arno Handsfn might work... I'm trying to track down Architxt.ttf which is in some of the annotation families here and was discussed in some older forum links. Even pay sites don't seem have this particular one. I'll keep searching. It is similar to an shx that we use on acad
Wed, Feb 16, 2005 at 9:14:03 AM | RE: Architectural fonts
arnosandoval
5 Stars: 3 Votes
Architxt.ttf is available and I have it on my computer at home, I will bring it in for you, the only thing it it really does not look like the shx font that I think you are talking about. The Handsf Single font is closer to the Architxt shx that you are talking. Let me know if you still need it.
Sun, Mar 6, 2005 at 10:30:27 PM | RE: Architectural fonts
timOthyj
4.5 Stars: 14 Votes
whoa.. I have the architext and ARchitxt fonts loaded and they work just fine they are of course TTF I could send to you if you wish.
Mon, Mar 7, 2005 at 8:33:27 AM | RE: Architectural fonts
arnosandoval
5 Stars: 3 Votes
Do they look, architecturally speaking or are they looking like simple txt from autocad. If they look architecturally speaking I would love to take a look if you don't mind. Thanks
Mon, Mar 7, 2005 at 2:30:00 PM | RE: Architectural fonts
mtropper
As Arnosandoval has recommended, Handsfn.ttf looks pretty good but I wouldn't mind a copy of architxt.ttf too for comparison. I found the architxt.ttf that looks like simplex from acad also, out in the deep dark crevises of the internet.....its scary what you might find out there...
Thu, Mar 31, 2005 at 1:40:36 PM | RE: Architectural fonts
arnosandoval
5 Stars: 3 Votes
Mtropper, Curious where you able to get the Architext font to work? timOthyj, Is it possible for you to post those two fonts, it's something that I just want some clarification. Thanks in advance.
Thu, Mar 31, 2005 at 2:20:15 PM | RE: Architectural fonts
LastSpartanStanding
Try using Stylus BT which is a standard Windows True Type font. You won't have to worry about sending the font with your files to other users. It will give your drawings a hand lettered look and is very legible and free.
Thu, Mar 31, 2005 at 2:26:33 PM | RE: Architectural fonts
arnosandoval
5 Stars: 3 Votes
Thanks, I am aware of the Stylus BT, it's a nice font, and has worked in the past, but not quite what I'm looking for. Really what I would like to see happen is Revit either accept shx fonts or have them include some Architectural fonts with the software. That is just me.
Thu, Apr 14, 2005 at 9:47:26 PM | RE: Architectural fonts
#11
mtropper
Just an update.. We started to use handsfn.ttf. It seems to do the trick. It looks good but its scale is kind of funky. What ever size you need it needs to be reduced about 75%. Shx would be nice for all of us former Acad junkies...
Tue, Apr 19, 2005 at 9:33:44 AM | RE: Architectural fonts
#12
jstewart
We use this ARCHITXT font and it works fine except sometimes when you export PDF files!
Tue, Apr 19, 2005 at 2:22:31 PM | RE: Architectural fonts
#13
arnosandoval
5 Stars: 3 Votes
JStewart, Thank you. This is the font that I was looking for. It looks great, and am looking forward to using it on my projects.
Mon, Feb 12, 2007 at 4:11:26 AM | jstewart
#14
ericwing
Quoting jstewart from 2005-04-19 09:33:44
"We use this ARCHITXT font and it works fine except sometimes when you export PDF files! "
Awesome! I have been looking for this!!!! I owe you one.
Wed, May 2, 2007 at 10:57:19 AM | Architectural fonts
#15
ryder217
5 Stars: 3 Votes
I say thanks to old threads... i've been looking for this font
Architectural fonts
Fri, May 13, 2005 at 2:04:42 PM
Fonts For Revit
Mon, Oct 8, 2007 at 8:19:03 AM
fonts
Thu, Feb 24, 2011 at 2:57:05 PM
TTF Fonts for Revit
Mon, Jun 5, 2006 at 3:38:49 PM
FONTS!
Thu, May 4, 2006 at 2:46:59 PM
Page generation time: 0.4795
