Forums >> Community >> The Studio >> Windows Vista
Wed, Jan 31, 2007 at 9:14:07 AM | Windows Vista
hammer87
hammer87 Avatar
3 Stars: 4 Votes
anyone have an idea on weather Revit will work with Vista? just wondering because in a few months here im going to be getting a laptop and was wondering on the compatilbilty.
My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087
Fri, Feb 23, 2007 at 10:07:18 AM | Windows Vista
vart41
I just got a new computer last night with windos vista and neither autocad or revit work on it.  Autodesk is suppose to be working in a patch to solve the problem.
Esteban
Fri, Feb 23, 2007 at 3:08:12 PM | Windows Vista
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok thanks for the tip. hopefully the patch is out by june since thats when i graduate
Mon, Feb 26, 2007 at 9:58:34 AM | Windows Vista
Thread Post Kudo! #4
sjohnson
I just bought a new desktop with Vista Ultimate on it and was able to get Revit working just fine.
This is how I installed
1) Make sure you are a full Admin user
2) Turn off Windows Defender in services
3) Turn off Windows firewall and verify in services
at this time I didn't even have antivirus, I didn't want to take a chance on anything interfering with the install.
4) Ran install as admin
Once installed all I have been doing in order to run Revit is to run the program as admin, and it’s been working great.
I may have taken more steps than needed, but it did work and is still working on my Computer.
sjohnson
Wed, Feb 28, 2007 at 6:27:58 AM | Windows Vista
Admin
admin
Admin Avatar
3 Stars: 4 Votes
I can confirm that the above works!
I actually followed a normal installation, not disabling anything. The only thing I did different than any other program to get Revit Building 9.1 to run was right click on Revit Building 9.1 in the start menu and select run as administrator.
Pierced Media, LC
Sat, Mar 10, 2007 at 8:26:08 PM | Windows Vista
Ace001
Is your new Vista system running on a 64bit or 32bit system?
Sat, Mar 10, 2007 at 10:07:29 PM | Ace001
Admin
admin
Admin Avatar
3 Stars: 4 Votes
Quoting Ace001 from 2007-03-10 20:26:08
"Is your new Vista system running on a 64bit or 32bit system?"
It is 32 bit running on an old 32 bit AMD 2800+ processor with 1Gb or RAM
Pierced Media, LC
Mon, Mar 12, 2007 at 8:11:40 AM | Windows Vista
sjohnson
I am also using 32 bit Vista
sjohnson
Mon, Mar 12, 2007 at 8:35:35 AM | Windows Vista
broncos4life
3.5 Stars: 11 Votes
Im not sure with the latest eddition, but I had Revit working with both Vist RC1 and RC2.  Both RC1 and 2 were ultimate and both were x64.  So I dont know if that helps, but it has been working for me with out any problems.
Grant Doherty
Mon, Mar 12, 2007 at 8:43:05 AM | Windows Vista
hammer87
hammer87 Avatar
3 Stars: 4 Votes
from what ive read i guess vista would be good if i got a laptop
Mon, Mar 12, 2007 at 9:15:45 AM | HELP! My Revit is not working with Windows Vista
#11
pupito
I just got a new machine with Windows Vista Business and my network deployment of Revit Building 9.1 is not working. I followed the advice from some of the posts above like, "run as administrator" and even tried running it in Windows XP SP2 mode to no success. I also installed it with full admin rights and turned off services for Windows Firewall and Defender. First of all, Windows is requesting permission to run Revit because it does not recognizes it as installed. I click OK to allow it to run. Revit tries to initiate then it crashes. The message is: Revit has stopped working, Event name: APPCRASH, Fault Module name: Secur32.dll. Interestingly enough Architectural Desktop 2004 works just fine. Can anyone help me figure this one out, please?
The computer is a Dell Precision 390 with Intel Core(TM)2 CPU 6400@ 2.13GHz, 3.25GB RAM, NVidia Quadro FX3450/4000 SDI.
Mon, Mar 12, 2007 at 9:27:38 AM | Windows Vista
#12
sjohnson
I only did a standalone docked install of Revit 9.1 not a network. I would assume with a network install Vista is blocking some stuff. Can you do a standalone?
If you have been using Vista you might notice that its constinataly asking for permission for everything UNLESS the application is Microsoft Certified. Revit is not yet Microsoft Vista Certified, therefore Vista does not trust anything it does. And I believe that a network install would require Revit to have more permissions than a standalone installation.
sjohnson
Mon, Mar 12, 2007 at 11:07:49 AM | Windows Vista
#13
pupito
Thank you very much! I installed Revit as a stand-alone and it works. Thanks for your help!
My question is, is it possible to create a network deployment that works with Vista? What if I recreate my network deployment folder from the WVista station then use it to install network licenses on other WVista stations, would that work. Is the stand-alone option the only way Revit 9.1 will work under Vista?
Mon, Mar 12, 2007 at 11:59:13 AM | Windows Vista
#14
sjohnson
Its possible that it could work but, I think its going to run into right issues again. I would stick to docked station installs unless you got the time. Vista is very locked down and unless the application is signed it limits its right to what it can install and to what information it can pull from another location.
sjohnson
Thu, Jun 21, 2007 at 1:22:29 PM | Windows Vista - Revit Architecture 2008
#15
rkitect
rkitect Avatar
4 Stars: 29 Votes
Just an Update.  Just got a new computer at the office.
Windows Vista Ultimate 32bit2GB Ram512mb nVidiaRA2008 and AutoCAD 2008 both run perfectly on the machine.  No hickups during install or while running.  I am very pleased.
Does Revit 2009/2010 work properly to on Windows 7
Thu, Jun 3, 2010 at 4:25:04 AM
12
Revit 2011 Network Drives Disconecting for Windows Vista
Tue, Sep 21, 2010 at 2:05:39 PM
Revit and Windows Vista Beta
Fri, Nov 17, 2006 at 11:11:36 AM
User Material file Location in Vista
Wed, Sep 23, 2009 at 11:23:50 PM
HP DESIGN JET 1050C FOR VISTA 64 BIT
Fri, Apr 18, 2008 at 6:39:35 PM
Page generation time: 0.2036
