Forums >> Community >> The Studio >> KOHLER TUBS
Thu, Oct 14, 2004 at 7:52:27 AM | KOHLER TUBS
Bimman
Bimman Avatar
1 Stars: 2 Votes
HJ, I NOTICED YOU HAVE DONE ALOT OF THE KOHLER TUBS AND SINKS. CAN YOU UPLOAD A COPY OY THE K-1248 6' SEASIDE TUB. THE K-1247 IS THERE BUT IT IS A 5' VERSION WE ARE PUTTING THE 6 FT IN OUR PARADE HOME THIS YEAR. ALSO WHERE DID YOU GET THE FILES TO DO THAT FROM? THANKS BIM MAN Post edited on 2004-10-14 07:53:42
PWD
Thu, Oct 14, 2004 at 9:04:05 AM | RE: KOHLER TUBS
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I got all of those files from the Kohler website and imported to Revit. I uploaded all of the 3d files I could find on their website, you might want to check there... http://www.kohler.com
Hiroshi Jacobs
Thu, Oct 14, 2004 at 9:05:09 AM | RE: KOHLER TUBS
Bimman
Bimman Avatar
1 Stars: 2 Votes
Thanks i'll go there now
Thu, Oct 14, 2004 at 12:03:30 PM | RE: KOHLER TUBS
shanetrammell
do you guys know of any other companies that have these downloadable families? Post edited on 2004-10-14 12:03:56
Thu, Oct 14, 2004 at 12:36:32 PM | RE: KOHLER TUBS
Bimman
Bimman Avatar
1 Stars: 2 Votes
i think that most of your larger companies have dwgs or dxfs for download but i have never converted them to revit families. i do know that they are not parametric. hj may be able to explain what you need to do to convert them over to an rfa
PWD
Thu, Oct 14, 2004 at 1:40:09 PM | RE: KOHLER TUBS
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
If they do have them in dwg, they are not parametric...but they really don't need to be since they are specific items. To make a family out of it, you simply import the 3d dwg file into a family template file, set up the (non-size) parameters you need (ie. cost, manufacturer, etc) and save as a new family. I don't know of any other manufacturers that have 3d dwg or dxf files of their products, but I'm sure they're out there...
Hiroshi Jacobs
Thu, Oct 14, 2004 at 1:53:38 PM | RE: KOHLER TUBS
Bimman
Bimman Avatar
1 Stars: 2 Votes
I THINK PELLA AND ANDERSON DO
PWD
Thu, Oct 14, 2004 at 2:15:52 PM | RE: KOHLER TUBS
shanetrammell
yeah i have seen the andersen stuff and i think that i have seen the pella, i was just trying to find as much as i could.
Thu, Oct 14, 2004 at 5:51:53 PM | RE: KOHLER TUBS
Mr GG
3.5 Stars: 9 Votes
No Tubs But nice 3D-models in .dwg and .3ds format: http://www.hermanmiller.com/CDA/SSA/Category/0,,a4-c410,00.html What do you say about this one - something to place beside the tub?
Fri, Oct 15, 2004 at 7:36:57 AM | RE: KOHLER TUBS
Bimman
Bimman Avatar
1 Stars: 2 Votes
Herman miller stuff looks good. do you know of any good residential furniture out there.
PWD
Fri, Oct 15, 2004 at 9:18:28 AM | RE: KOHLER TUBS
#11
Mr GG
3.5 Stars: 9 Votes
I Googled for: residential-furniture ".dwg" download I found 1110 links... I have not looked through all of them But I think it is a bit hard to find .dwg-files... Here is one with a lot of stuff but it is .max not .dwg http://www.mr-cad.com/default.php?cPath=38
Fri, Oct 15, 2004 at 12:48:50 PM | RE: KOHLER TUBS
#12
shanetrammell
thank you for the herman miller link. what extensions do the files need to have to be used in revit?
Fri, Oct 15, 2004 at 2:25:14 PM | RE: KOHLER TUBS
#13
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
well you can import dwg & dxf files...and a lot of 3d programs can export to dwg. I know for a fact that Form-Z can and MaxLloyd's tutorial on revitcity says that you can export to dwg from 3DS Max...
Hiroshi Jacobs
Fri, Oct 15, 2004 at 3:58:41 PM | RE: KOHLER TUBS
#14
shanetrammell
ok thanks a lot. if anyone else knows of anymore places to dl these files please post up a link!
Sat, Oct 16, 2004 at 4:48:17 AM | RE: KOHLER TUBS
#15
Mr GG
3.5 Stars: 9 Votes
I had a look out for free 3D-models. Many models are in the .max-file format. So I tried to search for a file-converter for .max to dxf or to .dwg. I did NOT find any! So if someone finds a free converter from max to dxf or dwg so please - the link! OK! I found something. http://www.neeneenee.de/vrml/downloads.html Here you can find seven converters but no free one for max to dxf/dwg There are free ones for 3DS to DXF/DWG Have a look around on this site. This site is for X3D eaarlier called VRML. Have a look also on eg. VRML-plugins some of them are for X3D and you can show your Revit 3D-model in a web-browser. There is a X3D-exporter for 3DStudio Max. This is not an easy world to master. It is a Babylonian-world but have a try... X3D is very interesting because it is a W3C STANDARD that can be used to save drawing in SECURE-.format because the drawings are saved as plain text readable in eg. Notepad. I REALLY hope that Revit will make it possible to export and also import in X3D-format. You can read more here: http://revitcity.com/forums.php?action=viewthread&thread_id=520 X3D-tools you find here: http://www.web3d.org/applications/tools/ Here you can have a look for converters: http://www.3dlinks.com/links.cfm?categoryid=1&subcategoryid=11 And here are also converters not only for VRML: http://vrmlworks.crispen.org/convert.html Crossroads you can use to convert betwwen 3DS and DXF http://www.europa.com/~keithr/crossroads/ To find free models you can go to: http://www.3dlinks.com/ and Search for: free models and you will get some pages with links Just as an example: free .max-models: http://www.cad-com.net/cc_model_X.php And here free 3D-objects: http://www.3dlinks.com/oldsite/objects_free.cfm This converter perhaps is interesting to someone: http://www.cad2cad.com/en/dtpexpress.htm I have used it for converting DWG to EMF to import the EMF file into FLASH There is demoversions that can be used with a little smartness just deleting the demo.-text! If someone finds a DWG/DXF free converter to SWF the file format of FLASH I am very interested... The only I have found for DWG-to-SWF convertion is: http://www.vecta3d.com/ These furniture is not free furniture but they are for Accurender 3 - can be interesting for Revit 7 that will support Accurender 3: http://www.abscissa.net/views.htm
kohler toilet inserting as elevation in floor plan
Wed, Sep 2, 2015 at 12:43:24 PM
Kohler toilet shows up as a cube?
Thu, Aug 29, 2013 at 1:15:05 AM
Kohler toilet fixtures will not download
Thu, Mar 4, 2004 at 4:29:44 PM
excessive polygons
Wed, May 20, 2009 at 2:57:55 PM
Materials
Fri, Jun 29, 2012 at 8:50:54 AM
Page generation time: 1.9440
