Forums >> Revit Building >> Technical Support >> A Serious Error
Thu, Sep 14, 2006 at 2:29:37 PM | A Serious Error
derxaj
3.5 Stars: 3 Votes
Hey has anyone else ever had the error pop up that says "A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing." And then the only option is to "Continue without saving"? I know its happened to me at various times before, it just did when I tried to transfer view templates from one file to another. Does anyone know if there are any serious issues associated with this error? I know in that past I've just kept working and nothing seemed to be different. Just wondering if this ever happens to anyone else and if anyone know's what it really means. Adam
Fri, Sep 15, 2006 at 12:46:35 AM | RE: A Serious Error
Rusyel
I hve experienced this when upgrading a project from more than 2 versios ago, eg upgraming from 6.1 to 8.1 or above. Usually the porject has something in it specific to the previous version which it cant translate into the more recent one. Hope this helps.
Fri, Sep 15, 2006 at 1:10:56 AM | RE: A Serious Error
johann
I receive this same error when busy with sitework. When creating pads or subregions I have experimented with creating 2 simultaneously (2 pink squares), but Revit seems unable to create these. When attempting the same process while creating floors it works and you then have 2 separate areas of floor with similar properties. Unfortunately it is a no-go for Subregions & Pads. Post edited on 2006-10-02 03:28:15
Fri, Sep 15, 2006 at 8:36:17 AM | RE: A Serious Error
derxaj
3.5 Stars: 3 Votes
Yah...this error seems to happen at various times...its strange because it happens so randomly. An why is it called a "Serious Error" when you can just keep working like it was nothing. Anybody else get this error or know what the real cause of it is?
Fri, Sep 15, 2006 at 1:43:50 PM | RE: A Serious Error
ArchWestCY
4.5 Stars: 7 Votes
I have gotten that error when editing curved walls. I tried and tried to get around it. I worked every variasion and angle I could think of. Finially I offset the wall. Edited the new wall to be the way I wanted it. Then, deleted the old wall, and offset the new wall back into place. What happened? Why? I have no idea. I does seam to be somewhat random, but when it happens Revit really doesn't want to do what you ask. I just grit my teeth, bite my tonge, and try again. Good Luck ArchWestCY
Mon, Sep 18, 2006 at 2:28:16 AM | RE: A Serious Error
nandini
When a revit session is opened, do not close the default new empty templete thats opened..that helps..this helps ina great to not get error... after this if the error still occurs, its more because of many applications or many files opened in revit. its a way of revit handling too much of stress..!!
Mon, Sep 18, 2006 at 11:24:01 AM | RE: A Serious Error
derxaj
3.5 Stars: 3 Votes
Hmmmm...interesting Nandini...has anyone else ever tried doing that? Keeping the empty drawing open? I'm suprised if that really works like you said.....considering the error we are talking about happens very randomly and not very often at all. Adam
Mon, Sep 18, 2006 at 11:56:04 AM | RE: A Serious Error
administrator
yeah i have had this error as well, it was ahwile back with revit 8 it had something to do with my schools server i dont remember
Mon, Sep 18, 2006 at 7:12:48 PM | RE: A Serious Error
cartman
We have lost many files since upgrading to 9.1 our problem appears to be files linked to our server. We have had no problems since saving direct to our PC's. Have spent several weeks of fustration and loss of work. Our re seller has been working with our IT since the upgrade and indicated that we were the only ones with a problem??
Mon, Sep 18, 2006 at 7:17:58 PM | RE: A Serious Error
Rusyel
Cartman youre not the only one with the problem, We have had confirmation from autodesk that it is an issue with 9.1 when saving across a network. We havent experienced it ourselves but have heard of it happening. It is apparently linked to a particular set of hardware configurations which REVIT doesnt like for some reason. If you contact Autodesk derect they may have more info for you (and maybe have a hard word to your reseller to check their sources...)
Wed, Sep 20, 2006 at 12:40:32 PM | RE: A Serious Error
#11
derxaj
3.5 Stars: 3 Votes
Yah even though this isnt the error I was talking about when I started this thread, I have heard of a few people who have recently had problems with saving to a server. There are other discussions that have talked about this as well. We recently decided to save all of our local files on our computers local harddrives so that we have them as a backup incase something happens with the central files on the server. Have you tried that yet Cartman? Does everyone recommend upgrading to 9.1 from 9.0 or are their too many problems with it? We are still running 9.0 and have never had problems with the server. Adam
Wed, Sep 20, 2006 at 7:53:31 PM | RE: A Serious Error
#12
Rusyel
Its definately a problem specific to 9.1. The advie we have recieved is that if you upgrade to 9.1 and dont experience any problems almost striaght away then you shouldnt experience any at all. But if you do get probllems saving to a server then they have no solution, kind of makes it hard to decide to upgrade if you dont know you have a problem until you have it.
Thu, Sep 21, 2006 at 9:58:15 PM | RE: file back up
#13
cartman
Adam
Thu, Sep 21, 2006 at 10:07:32 PM | RE: File backup to server
#14
cartman
Adam
Yes Adam we are backing up to our individual PC's with no corrupt files since. Has anyone heard of this happening outside of Australia?
Thu, Sep 21, 2006 at 10:52:56 PM | RE: A Serious Error
#15
hisdirt
5 Stars: 5 Votes
Cmon ya aussies! Pull it together!
Render Calculation Error? [ 1 2 ]
Fri, Jun 7, 2013 at 7:53:38 AM
19
Feet per second squared error? What?? [ 1 2 ]
Wed, Feb 20, 2013 at 2:26:22 AM
18
Revit Error on Shutdown
Sat, May 21, 2011 at 9:43:15 PM
12
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:48 PM
Error id 124491
Mon, Jul 9, 2012 at 10:44:33 AM
Page generation time: 0.1165
