Forums >> Revit Building >> Technical Support >> Explode Families?
Sat, Jul 8, 2006 at 2:28:18 PM | Explode Families?
JRkitekt
Does anyone know a way to explode famies?
Tue, Jul 1, 2008 at 5:56:09 PM | Explode Families?
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Same here
I’m keen to find out if there is a way to explode already placed families within a family file.  For example, I have a heap of nested families that I want to reduce there file size so I want to explode the nested component.   Otherwise I have to cut and paste each component (from other family files) to make up my families.
There must be an easier way???
Wed, Jul 2, 2008 at 2:43:16 AM | Explode Families?
Elmo
3.5 Stars: 4 Votes
There is no way of exploding a family as far as I'm aware.
Wed, Jul 2, 2008 at 10:00:35 AM | Explode Families?
lunchtrayrider
3.5 Stars: 7 Votes
no explode no xplode nnnnnooooooooo
I like scooters. and motorcycles.
Wed, Jul 2, 2008 at 12:11:20 PM | Explode Families?
psemrau
That I know... it can't be done, not even copy-paste the elements between family and project....
Wed, Jul 2, 2008 at 6:09:43 PM | Explode Families?
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
I was able to copy elements from my family file to another family file.
I recreated 1 of my many nested families to a non-nested family.  The non-nested family was half the size.  Thanks RTC
Fri, Jul 4, 2008 at 8:09:25 AM | Explode Families?
Elmo
3.5 Stars: 4 Votes
There is only one way of 'copying' across a solid across from a family to a project and vice versa. What you need to do is edit your extrusion and copy the lines with ctrl-c. Then inside your project you need to create a similar process by starting the extrusion and going ctrl-v to paste the lines across. This is essentially the only process that I am aware of that will do what you need to have done.
Tue, Jul 8, 2008 at 10:16:59 PM | Explode Families?
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
I'm with trayrider, just say no to splodes. Nested families are some of my favorite kinds. A friend of mine has been experimenting with compaction and purging of nest families and reloading them through all nested sequences and into the project. He claims up to 2/3 reductions in file size and tangible performance gains. Might be something to try, expecially since it might keep a loving family from being ripped apart.
Wed, Jul 9, 2008 at 6:33:08 AM | Explode Families?
lunchtrayrider
3.5 Stars: 7 Votes
purge yes, explode no.  I really doubt that the familiy size going from 300kb to 150kb or whatever is really going to help the speed of revit, but the loss of control over a familiy is real tangible time that can be lost when it needs to be changed.
Wed, Jul 9, 2008 at 7:07:25 AM | Explode Families?
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
I seriously hope he's not worried about 150k. The friend that I reference had a 9GB family drop to 3GB. Now that's a chunk of file-size worth spending a few moments to recover.
Wed, Jul 9, 2008 at 8:45:11 AM | Explode Families?
#11
lunchtrayrider
3.5 Stars: 7 Votes
What in gods name could be in a 3gb family????!?!?!?!?!
Wed, Jul 9, 2008 at 9:33:19 AM | Explode Families?
#12
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
sorry, couldn't help myself...
I think he was building a pretty complicated section of stadium seating. External makes it a LOT easier to edit. In hind-sight, probably would have been better as a separate Revit project file linked in.
Edited on: Wed, Jul 9, 2008 at 9:34:39 AM
Wed, Jul 9, 2008 at 10:53:03 AM | Explode Families?
#13
lunchtrayrider
3.5 Stars: 7 Votes
yea but revit isn't even 3gb let alone a singular family.
Wed, Jul 9, 2008 at 11:05:18 AM | Explode Families?
#14
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
true, i meant megs not gigs...but the "your mom" is funnier with gigs.
Wed, Jul 9, 2008 at 12:24:33 PM | Explode Families?
#15
lunchtrayrider
3.5 Stars: 7 Votes
now I want to make a 3gb family and put it in our standard template.
Can't explode in 2010
Fri, Apr 17, 2009 at 4:13:21 PM
How to explode anonmeetric walls for detail drawings
Fri, Feb 28, 2014 at 5:04:59 AM
Autocad 3d solids dissapear once I 'full explode' the model in Revit
Wed, Jun 11, 2008 at 9:07:12 PM
import & explode dwg detail
Tue, Nov 28, 2006 at 10:08:04 AM
linking from acad
Sun, May 15, 2005 at 12:43:42 PM
Page generation time: 0.3076
