Forums >> Community >> Newbies >> Cannot find the model or family I just imported!
Fri, May 19, 2017 at 2:02:00 PM | Cannot find the model or family I just imported!
shabik
Hi
I just imported this rotating door from this website. I then go to project  browser and I can see it is nicely located under DOORS/ but how the hell do I insert it from there? The other door i imported automatically got put into the door-category along with the default door but this one not. It is a revolving door btw, not sure if it matters. Does anyone know what the problem might be?
Fri, May 19, 2017 at 2:26:20 PM | Cannot find the model or family I just imported!
CDWdavid
5 Stars: 5 Votes
It might be a curtain wall door.
Fri, May 19, 2017 at 2:41:56 PM | Cannot find the model or family I just imported!
shabik
So how do I find that? In the project family, it is listed in the door-category together with the other door. Btw, I imported a second version and the same thing happened, it is only visible in the browser under door but not if I go architecture/door its not there.
Fri, May 19, 2017 at 3:24:27 PM | Cannot find the model or family I just imported!
Curtain wall 'doors' are replacements for curtain wall panels.  Place a curtain wall, then select a panel and swap that out with the CW door.  Obviously, the panel size needs to be the right size to accomodate the door.
Sat, May 20, 2017 at 3:22:49 AM | Cannot find the model or family I just imported!
shabik
Hmm that is a bit strange given that a revolving door is round 180 diameter while a curtain wall is a straight line. Btw, I dont think that worked so well but im relatively new at revit so i might be doing it wrong. I selected the curtain wall, then edited the properties but there are only the normal wall options. Then I went to project browser and tried double click and dragging the revolving door but no luck.
Sat, May 20, 2017 at 8:19:21 AM | shabik
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting shabik from 2017-05-20 03:22:49
Not the wall, select a panel that you want to replace and swap it with the door in properties. See this.
Sat, May 20, 2017 at 8:51:26 AM | Cannot find the model or family I just imported!
shabik
Okay thanks sor helping but again, it is a revolving door, not a curtain wall door. You can see it in a brick building!
Sat, May 20, 2017 at 9:17:14 AM | Cannot find the model or family I just imported!
Don't be stubborn here and listen!  Many of the revolving doors here on the site are curtain wall doors!  You don't bother to tell us what family so we can only guess based on what you tell us.
Sat, May 20, 2017 at 9:18:48 AM | Cannot find the model or family I just imported!
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Can you upload your door family or give us a link?
Sat, May 20, 2017 at 10:02:11 AM | Cannot find the model or family I just imported!
shabik
I have tried 3 revolving doors. thanks for the video btw, I have this issue that other people on youtube seems to have;
The wall acts a a whole and not individual panels. I can delete the mullions but not select the individual panel. Thanks again for your time and patience!
Sat, May 20, 2017 at 10:27:36 AM | shabik
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting shabik from 2017-05-20 10:02:11
Hover your mouse over the edge of the panel and keep hitting tab key until it highlights.
If no go, upload your file.
Sat, May 20, 2017 at 12:40:51 PM | Cannot find the model or family I just imported!
shabik
Woho!! That was it! Wow, that was a complicated manuever, had to tab like 23 times to get it and accidently skipped through it, why do they have a control system like that? Didnt know I had to create a curtain wall to create a revovling door, now there is an opaque wall above, no idea how i can change that to brick.
Sat, May 20, 2017 at 1:17:50 PM | shabik
#13
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting shabik from 2017-05-20 12:40:51
You didn’t upload your file and you didn’t give us any screenshots, so I can only guess what you’re doing, it may or may not be the best solution in your case - select CW, go to edit type, check ‘automatically embed’, reduce the size of your CW to the size of the door and draw your brick wall over it.
Sat, May 20, 2017 at 1:27:21 PM | Cannot find the model or family I just imported!
#14
shabik,
Give it time, this process is far easier than you are experiencing.  Most of us can tab to the panel in 2 clicks or less, you just need more experience.
The CW revolving door was created for typical full CW buildings.  If you don't have any other needs for the CW, then a different family may have been better.  You can follow pijpiwo's advice if you want your brick wall above.   In a typical CW, that might be a glass panel.
Sun, May 21, 2017 at 6:27:40 AM | Cannot find the model or family I just imported!
#15
shabik
Thanks so much guys for all your help, also a good recommendation to half the wall size and add another tall on top of it even though it is on the same level. I really appreciate all the help here, great forum!!
How do I Delete Imported Catagories?
Wed, Nov 29, 2017 at 6:19:19 AM
Changing colors and materials in an imported model
Fri, Dec 17, 2010 at 4:55:47 PM
Imported dwg files
Wed, May 10, 2017 at 10:25:29 PM
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:09 AM
Create a new family from a 'model in place'
Tue, Jan 17, 2017 at 12:57:22 PM
Page generation time: 3.6929
