Forums >> Revit Building >> Technical Support >> ramps presentation
Sat, Jul 27, 2013 at 9:12:12 AM | ramps presentation
solidsnakeala
hi ... using revit  2013 , what is the best way to make a nice presentation for the ramps ???
Mon, Jul 29, 2013 at 10:03:45 AM | ramps presentation
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not enough information here to help you.  We need to know exactly what you are doing and looking for.  i'm assuming a 3D perspective rendering is what you would want to try.
Mon, Jul 29, 2013 at 2:41:48 PM | ramps presentation
solidsnakeala
thank you .. sorry for not giving much info ....
actually no not 3d what i meant ... please see the attachement that shows what i need . this was an acad drawing ...
thank you ...
Mon, Jul 29, 2013 at 5:07:41 PM | ramps presentation
RevitMaestro
I would model the ramp using the ramp tool.
As far as the arrows and the graphics I would create those using drafting lines, and create a group to keep them all neatly together.
Mon, Jul 29, 2013 at 5:10:49 PM | ramps presentation
RevitMaestro
Unless those are painted lines on the ramp in your picture, which would show up in 3-D ( I assumed they were just descriptive graphics? not sure.)  In which case I would create an in-place family, create objects or lines by setting the work plane to the surface of the ramp within the in-place family.
Tue, Jul 30, 2013 at 2:31:36 AM | ramps presentation
caddeva
please be specify. wat you are looking for ? you mean 2D presention?
Tue, Jul 30, 2013 at 3:23:48 PM | RevitMaestro
solidsnakeala
Quoting RevitMaestro from 2013-07-29 17:07:41
but i think the ramp tool in revit is stupid . it doesnt cut with the plan cut line . and its not calculated for shadows ..
and what i realy want is a good method to make  the  ramp well presented in 2d on the plans and sections ..... and what i specificly want is ( HOW TO MAKE THIS NICELY PRESENTED CUT WITHIN THE RAMP ) ??
Tue, Jul 30, 2013 at 4:35:51 PM | ramps presentation
RevitMaestro
to create the diagonal cut line make a plan region in the view.  also use a floor with a slope arrow to create the ramps.
first i created the floor with slope.  in this case i made the slope arrow to be 1.2"/12" to get the 10% slope.  see image.
i created several of these floors and joined them together using the join geometry view. see section view.
then in the 2nd level plan view i created a plan region set to 0" above level 2.  the plan region was drawn at the desired angle to give the diagonal cut.  also you can see the ramp to the right coming up from below.  the plan region dashed outline will not print.  see image.
lastly, the only reasonable way i could find to get a double cut line, if its necessary, is to create a solid white filled region.  other than this the graphics are all up to you.
let me know if this helps.
122692_create_floor.jpg122692_section_view.jpg122692_plan_region.jpg122692_filled_region.jpg
Tue, Jul 30, 2013 at 4:55:38 PM | ramps presentation
solidsnakeala
thank you so much that was what i want but you said: " the plan region was drawn at the desired angle to give the diagonal cut "
how did you do that !
thanks,
Tue, Jul 30, 2013 at 5:14:39 PM | ramps presentation
RevitMaestro
in the plan region sketch mode, you can create the plan region to be in any shape you want, to create the desired diagonal cut.  draw the sketch lines in the diagonal that you want.
Wed, Jul 31, 2013 at 5:46:29 AM | ramps presentation
#11
caddeva
solidsnakeala- i have tried this different method. see the attachement and let me know, if this is helps.
Wed, Jul 31, 2013 at 2:57:19 PM | ramps presentation
#12
solidsnakeala
ya i know this method but it doesnt make the diagonal cut ... thanks anyway Smile
Wed, Jul 31, 2013 at 2:59:54 PM | ramps presentation
#13
You are correct, it will not make a diagonal cut in plan ..... use a detail element!
Wed, Jul 31, 2013 at 3:03:01 PM | ramps presentation
#14
solidsnakeala
thanks for your concern
Thu, Jan 8, 2015 at 5:57:46 AM | ramps presentation
#15
blackcat052
i can't join them together cannot use " join geometry" . i don't know its mistake
Attach Walls to Ramps
Fri, Feb 18, 2011 at 6:45:16 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:53 AM
Ramps, What are they good for? Absolutely nothing
Tue, Dec 6, 2011 at 9:57:51 AM
Ramps
Wed, Aug 15, 2007 at 11:13:16 PM
Page generation time: 0.5763
