Forums >> Revit Building >> Technical Support >> Settings to view second level.
Fri, Feb 22, 2013 at 7:34:21 AM | Settings to view second level.
tacyb04
Kind of embarassed to ask because I'm sure this is very basic but I'm newish to Revit. I'm creating a two story house and when I click on the second level to draw the second level I can't see anything I've drawn on the first level. I tried to draw the second level walls from the site plan view just to see what would happen. I can put up the walls and see it in 3D and site plan but when I go to second level view I can't edit it or insert doors or windows. I think I have to set the view or something??? Also, in 3D the second story looks transparent. My settings must be off? Any help is really appreciated. Thanks!
Fri, Feb 22, 2013 at 7:41:17 AM | Settings to view second level.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Im a little confused.. you are trying to draw your second level walls but want to see the first floor?  In your properties turn on your UNDERLAY to first floor.
"I can put up the walls and see it in 3D and site plan but when I go to second level view I can't edit it or insert doors or windows"  Maybe its just me but this post isnt very clear.  You can put up what walls and see what in 3D, your second level walls? So when you go to your second level you can't see your second level walls after you have drawn them?
Fri, Feb 22, 2013 at 7:52:07 AM | Settings to view second level.
Goto an elevation view and make sure your level is where you want it to be.  I would assume that your exterior walls go past the second level to the roof.  Correct?
Mon, Feb 25, 2013 at 8:54:38 AM | WWHub
tacyb04
Quoting WWHub from 2013-02-22 07:52:07
I had to adjust the constraints because the second story walls were above the roof. I'm attaching pictures so hopefully that helps. I'm not good at describing it. In the 3D picture you'll notice all the doors are grayed out. In the 3D interior picture you can see the 1st level but the second level is all gray. And maybe the elevation view will help also. Thank you so much for any recommendations!! BTW I'm using Revit 2013.
Mon, Feb 25, 2013 at 9:31:45 AM | Settings to view second level.
Are you playing around with phases or design options?
Draw the second floor from the second floor plan - not the site.
Mon, Feb 25, 2013 at 9:43:05 AM | Settings to view second level.
tacyb04
I deleted the 2nd level that I drew in the site plan view. This brings me back to my original problem: When I open Level 2 I cannot see what I have drawn on Level one. So, I don't know how to get the 1st and 2nd story walls to align. Or am I not supposed to be able to see the first level in the second level? I'm attaching a picture of what I see when I open the second level view. Its just blank.
Mon, Feb 25, 2013 at 9:54:09 AM | Settings to view second level.
tacyb04
I drew 4 walls on the second level view and its not visible. I've attached the picture of what I see. There is one line from one wall that is visible in the picture I attached and the others are only visible if I select them. I also attached the 3D view of the four walls that I drew to give an understanding of what you should be able to see. Please note that the walls on the second level in 3D view are grayed out and transparent.
Mon, Feb 25, 2013 at 10:07:40 AM | Settings to view second level.
It looks like you have some fundamental problems.  How did you create your second level view?  The proper process is to click on the view tab and pick floor plan then select your level.  If you already have a scond floor plan, you will have to uncheck the do not duplicate box.
If your exterior walls (and or interior) go past the second floor level, they will show up.   If they don't, then are you looking in the right place.  Type ZE (zoom extends).
If you want to see the first floor walls on the second floor plan, you can change your view range and set your floor to transparent - or better - set the first floor as your underlay.
Mon, Feb 25, 2013 at 10:09:04 AM | Settings to view second level.
tacyb04
Just noticed the phase created was set to B10 - Superstructure. I changed them to Project Completed. I'm not sure how they got set to B10. The walls are no longer transparent in 3D but I still can't view them from the second level.
Mon, Feb 25, 2013 at 10:16:05 AM | Settings to view second level.
tacyb04
Mon, Feb 25, 2013 at 10:18:26 AM | Settings to view second level.
#11
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I think you need to spend some time reading up on how phasing is used.  You shouldn't have your plan set to project complete because well you are still doing it so it is not complete.  Existing should be drawn on existing phase, new phase on new phase, etc.  What is your phase set to on your second floor?  Did you try all of the things myself and WWHub suggested with using the first floor as the underlay?
Mon, Feb 25, 2013 at 10:19:56 AM | Settings to view second level.
#12
tacyb04
Changed the underlay to 1st level! Yay, now I can see it. I still can't change the visual style. Its stuck on hidden line and the options are grayed out. I normally like to work in realistic visual style. I've never had to change those setting before, so I'm not sure how they got messed up. Really appreciate the suggestions!!!
Mon, Feb 25, 2013 at 10:33:51 AM | Settings to view second level.
#13
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You may have a view template assigned to the view, you will need to change it there.
Mon, Feb 25, 2013 at 4:21:34 PM | Settings to view second level.
#14
tacyb04
Thank you both for the help! Any recommended reading material? I took a class on Revit back in 2009 and my employer wants me to use Revit now....so I'm very rusty and wasn't experienced to begin with. I think he imagines Revit as being some type of Paint for Architecture.
Tue, Feb 26, 2013 at 7:03:06 AM | Settings to view second level.
#15
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Maybe he needs to read up on Revit a bit then haha.  I would read the Mastering Revit Architecture books.  Cadclips.com has great tutorials to get you started and some advanced ones as well.
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:54 AM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Sections not Showing in Plan View
Mon, Oct 28, 2019 at 4:42:02 PM
View Scale to Detail Level Correspondence
Fri, Aug 15, 2014 at 1:28:19 PM
Family element Visibility Settings
Tue, Jun 11, 2013 at 4:08:30 AM
Page generation time: 0.8166
