Forums >> Community >> The Studio >> Create a Fence Line Type
Mon, Jan 23, 2006 at 8:35:47 AM | Create a Fence Line Type
stck2mlon
Is it possible to add text to a line pattern definition?
Mon, Jan 23, 2006 at 11:02:33 PM | RE: Create a Fence Line Type
eldados
eldados Avatar
4.5 Stars: 8 Votes
hmmm, not that I can see Sad you could import the line from Autocad if you have it there... (?)
Integrator
KarelCAD
Sun, Sep 9, 2007 at 9:26:14 PM | Create a Fence Line Type
gridcitypunx
wow great news
Sun, Jun 8, 2008 at 1:46:36 AM | Create a Fence Line Type
timbo89
timbo89 Avatar
4 Stars: 5 Votes
If by drawing a line that has letters or numbers or symbols in it you mean, I have a cheat solution that will work. The only downfall is that you can't draw curved lines;only straight ones. Start by creating a family that is a generic annotation. Create a label, and give the parameter any name you want, it doesn't matter. Make sure you centre it on the reference planes, as you need to be able to dimension the label. Create a new family, either generic model line based, or detail compoment line based, and load the generic annotation family into the line based family. Dimension from the label to the end refernce planes, and give the dimension a paramater like end gap or something. Array this group, selecting "last" in the array option, and dimension the array to the other refernce plane, giving the dimension a parameter. Give the array number a parameter, as this way you can control how many symbols are in the line. Load into a project, but instead of it being under line, its either under detail component or generic model. Draw the line away!
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Sun, Jun 8, 2008 at 1:58:21 AM | Create a Fence Line Type
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Here is a sample of what I made. It's in RAC2009
Thu, Jul 3, 2008 at 12:33:18 PM | Create a Fence Line Type
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
very nice, how do you change the letter?
Thu, Jul 3, 2008 at 5:46:28 PM | Create a Fence Line Type
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, I'll upload my latest version of that line, because it was created ages ago. To change the letter, go to the element properties and the option to change it should be there =) It's under a detail compenent. Hope you like it =)
Thu, Jul 3, 2008 at 6:05:44 PM | Create a Fence Line Type
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
that is amazing. thanks!
 cant believe RAC2009 didnt get this update...
 5 revit logos for you! Smile
Sun, Jul 1, 2012 at 11:08:48 AM | Create a Fence Line Type
Edwardf
Thanks for this.  It's a very clever solution.
Thu, Jun 5, 2014 at 9:48:59 AM | Create a Fence Line Type
MShareef
genius
thanks alot
Mon, Feb 8, 2016 at 7:23:09 AM | Create a Fence Line Type
#11
rizsec
OMG, thanks a lot!
Mon, Feb 8, 2016 at 8:22:52 AM | Create a Fence Line Type
#12
marmiketin1
4.5 Stars: 10 Votes
Here is a line style I have created with the option to change between squares, circles, triangles and diamonds which are all size parametric as well as spacing. It uses the process in whch timbo89 talks about. I have been using this for quite a few years myself.
Line Symbol is the label which contains the different types that are controlled through visibility.
Line Style iss the line with the arrayed symbol of your choosing by checking the visibilty parameter for the type
Mon, Feb 8, 2016 at 8:51:29 AM | Create a Fence Line Type
#13
marmiketin1
4.5 Stars: 10 Votes
Here is also a text line which adjusts the number of symbols based off the spacing value and the length of line. The text also has a transparent background. but this can be changed by editing the group then editing the label family and then changing the text to opaque background
Mon, Feb 8, 2016 at 11:55:57 AM | Create a Fence Line Type
#14
CDWdavid
5 Stars: 5 Votes
Hi marmiketin1,
Thanks!
I wish that we can embed those lines into walls, curtain walls and railings.
This way we can draw a wall or a fence to have the lines on the plans.
For walls, we can show ratings; for fences (we are using curtain walls) we can have the fence lines following the industry standards.
Mon, Feb 8, 2016 at 3:18:51 PM | Create a Fence Line Type
#15
marmiketin1
4.5 Stars: 10 Votes
Yeah definitely would be nice to have more options for wall graphics in plans. Even just having a fire seperation line type associatedthe walls for the seperations would be great.
The Hard Way to Create a Topo Fence - But it Works.
Mon, Nov 10, 2014 at 2:19:00 PM
creating a fence linetype?
Wed, Jun 10, 2009 at 6:35:46 AM
Complex Line Types
Tue, Oct 16, 2012 at 11:06:02 AM
Problems with Custom Fence and Egress Lines
Tue, Feb 3, 2015 at 7:15:13 PM
curved linetype for a fence
Fri, Apr 30, 2021 at 1:32:12 PM
Page generation time: 0.8351
