Forums >> Revit Building >> Technical Support >> Twisting 3D sweep
Tue, Jul 24, 2012 at 1:09:04 PM | Twisting 3D sweep
saleeby
saleeby Avatar
Revit Architecture 2012
When I sweep a non-circular profile down a 3-dimensional path, the vertical axis of the profile rotates
as the path changes direction. Is there a way to keep the vertical axis vertical so my profile is oriented correctly
as it sweeps down the path?
Thanks.
Tue, Jul 24, 2012 at 1:34:39 PM | Twisting 3D sweep
I have never had to answer this but can you control the profile orientation based on the relationship of the path to a plane hosting the path line?
Tue, Jul 24, 2012 at 1:44:02 PM | Twisting 3D sweep
saleeby
saleeby Avatar
The path is on a series of reference planes in order to get the 3D effect. I have tried to set the planes a variety of ways
to try and make the profile axis stay vertical, but it always twists as the angle changes. I tried a similar sweep in sketchup
and had the same effect, although not quite as severe. I think the computer twists it to make the changes in direction
clean up better.
Tue, Jul 24, 2012 at 1:47:49 PM | Twisting 3D sweep
What affect does checking the box "rotate with component" have in the profile family?
Tue, Jul 24, 2012 at 1:47:50 PM | Twisting 3D sweep
4 Stars: 205 Votes
Use "Swept Blend" (2 profiles) instead of "Sweep"
Tue, Jul 24, 2012 at 2:02:20 PM | Twisting 3D sweep
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
What is your host?
Unfortunately, your profile will use the ref. plane that the line you've picked belongs to.  IE, the roof plane of an eave.  Under some circumstances a series of profiles can remain vertical even with a 3D path.  So, what is this for?
Tue, Jul 24, 2012 at 2:40:20 PM | Twisting 3D sweep
saleeby
saleeby Avatar
Swept Blend does not allow more than 1 line segment.I did it that way, with a bunch of swept blends, but the don't clean up well.
The rotate with component didn't seem to help, see attached image.
And all my reference planes are perpendicular to the ground plane. I created them using a mass with vertical sides, see image.
I am trying to recreate a balcony condition at an existing church.
Thanks for all the help, btw.
Tue, Jul 24, 2012 at 3:16:27 PM | Twisting 3D sweep
saleeby
saleeby Avatar
This was the best I could get using a series of swept blends.
Tue, Jul 24, 2012 at 4:24:22 PM | Twisting 3D sweep
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Attached are two simple methods of creating ramps if that is what you are after, they are both roadway oriented but could be any section. The last is a half spiral stairs under construction that I designed a few years back on Revit, and using Robot for the analysis.
Tue, Jul 24, 2012 at 5:21:22 PM | Twisting 3D sweep
itsmyalterego
4 Stars: 16 Votes
a swept blend can also have a curved path.  But only one arc.  That's still plenty powerful, however.  You could make this railing in 1-2 segements, I think.  pic related.
Tue, Jul 24, 2012 at 7:34:52 PM | Twisting 3D sweep
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
What is the shape of the path in plan? Is it an arc? I see some straight segments in the original post. Is it supposed to be a series of straight segments or an arc?
Anyway, I agree with the previous posts that have suggested a swept blend, probably in some 3 pieces. See attachment foran example.
Edited on: Tue, Jul 24, 2012 at 10:08:59 PM
Planta1 Revit Online Consulting | info@planta1.com
Wed, Jul 25, 2012 at 8:44:54 AM | Twisting 3D sweep
saleeby
saleeby Avatar
It is an arc, but the path it follows doesn't have consistent slope, so one swept blend won't work. I tried (see pic)
but the highlighted blue arc doesn't follow the true path of the balcony. I could change the segmented swept blend paths
to arcs, but trying to figure out their individual paths is going to be tough.
Thanks for all the help.
Wed, Jul 25, 2012 at 8:54:20 AM | Twisting 3D sweep
#13
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
If it is a series of straight segments, at different elevations, probably you could use an adaptive family, similar towhat is shown in this video, adjusting the idea to your needs:
http://www.youtube.com/watch?v=GsJNn0pi994
Edited on: Wed, Jul 25, 2012 at 8:55:07 AM
Wed, Jul 25, 2012 at 9:17:45 AM | Twisting 3D sweep
#14
Alf - I would like to see your results using that family on something like a site plan that undulates in 3D.
Wed, Jul 25, 2012 at 9:48:48 AM | Twisting 3D sweep
#15
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
It works fine, given that there are references (workplanes, ref. planes, faces) that the points can use to attach to.
Formula driven mass - Sweep twisting of ground
Wed, Sep 2, 2015 at 2:12:40 PM
GENERIC MODEL SPIRAL SWEEP KEEPS TWISTING
Wed, Oct 16, 2024 at 6:03:13 PM
Can You Flex a Sweep in Components
Mon, Jun 3, 2013 at 2:09:23 PM
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:05 AM
Some help with twisting roof thing
Thu, Sep 4, 2008 at 3:47:21 AM
Page generation time: 0.1341
