Forums >> Revit Building >> Technical Support >> Feet per second squared error? What??
Mon, Jun 25, 2012 at 1:35:15 PM | Feet per second squared error? What??
jstewart
Every now and then I keep getting a "Feet per second squared" error when saving to Central.  Followed by a File not saved.  What in the world is that error all about?
today someone else got a Suare meters per meter error.
Mon, Jun 25, 2012 at 1:44:02 PM | Feet per second squared error? What??
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is this happening in one project only? Does the file still save?  Take a screen shot of the expanded error message and attach it.
Edited on: Mon, Jun 25, 2012 at 1:46:57 PM
Edited on: Mon, Jun 25, 2012 at 1:47:35 PM
Mon, Jun 25, 2012 at 2:57:49 PM | Feet per second squared error? What??
This may lead you to the problem: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=2767585&linkID=9273956
Tue, Jun 26, 2012 at 8:02:41 AM | Feet per second squared error? What??
jstewart
It has happend on a couple of projects.  We have sent the file to Autodesk to see what they can tell us.
Tue, Jun 26, 2012 at 3:45:03 PM | Feet per second squared error? What??
Warchitect
4 Stars: 5 Votes
maybe a structural error code in revit. like when calculation forces or somthing.
Tue, Aug 14, 2012 at 10:54:10 AM | Feet per second squared error? What??
earthtone
Haha I just tried to open a file that I have been working on for weeks now and got the error message: Kilometers per second squared - Cancel?
This is totally random, I am not working with anything that would need to deal with a measurement or conversion of acceleration.  Anyone figure out what's causing these errors?  Just trying to draw some boxes and set up sheets for project review with the city.  Looks like the backup files are fine, just the main that has been corrupted.
I literally was adding some detail lines to a site plan yesterday, edited a subregion of the topo, saved as normal and now this...?
Tue, Aug 21, 2012 at 10:29:36 AM | Feet per second squared error? What??
SRMiller
Has anyone got an update on this error? Just had an error pop up saying "Square Feet per foot" and then won't save.
Any update will be appreciated!
Tue, Aug 21, 2012 at 10:55:49 AM | Feet per second squared error? What??
SRMiller
Update, I came across another thread with similar error message "inches to the forth power" and it looks like it's a disk space issue. I deleted some files as suggested off of my flash drive and saved fine!
Hope this helps.
Sat, Sep 8, 2012 at 5:40:40 AM | Feet per second squared error? What??
aspect
5 Stars: 2 Votes
I'd second the disk space issue mentioned by #SRMiller as the culprit- I was getting the "Square Feet per foot" error until I cleared some disk space (hadn't realised I had used it all up). Made some space and problem solved.
www.aspectarch.com
Tue, Jan 15, 2013 at 9:07:08 AM | Feet per second squared error? What??
4 Stars: 3 Votes
No is not a disk space issue.
Tue, Jan 15, 2013 at 9:20:01 AM | image1
#11
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Quoting image1 from 2013-01-15 09:07:08
Sorry I believe you are incorrect. This message has to do with your project units and it relates to disk space.  If you clean up your disc space to free up more space on your network or computer your problem should be solved.
Tue, Jan 22, 2013 at 8:50:46 AM | Feet per second squared error? What??
#12
Straps
Straps Avatar
It is not a free space issue. I am getting Square Meters per Meter error and have PLENTY of free space..
Tue, Jan 22, 2013 at 8:57:28 AM | Feet per second squared error? What??
#13
Not sure if this is the problem or not but hear me out.  Microsoft has always had an addressable memory problem - especially with directories.  I'm not a computer genius so I can't fully explain what it is - I have just dealt with it all the way back,  Even as the systems progressed in total memory, they have never gotten fullly away from this error.
So try this and see if it works - if so please post.  Run c-cleaner to clean up all your files... especially temp file.
Tue, Jan 29, 2013 at 12:12:26 PM | Feet per second squared error? What??
#14
danielqu
I had a similar error and it did turn out to be a disk space issue.  Glad I found this post.
cdb-university.com
https://www.youtube.com/channel/UCJwS8p9S1Zyn2pqKwDsIs_Q?view_as=subscriber
Tue, Feb 12, 2013 at 8:21:33 AM | Feet per second squared error? What??
#15
muhaimi
does anyone got solution for this error? I got "square meter per meter"error and i cant save or recover my files... any solution to get my work back?
Line ends squared off instead of round
Tue, Jan 2, 2007 at 10:52:47 AM
Level Display (only) to decimal feet
Sun, Aug 10, 2014 at 11:00:01 PM
12
Rendering toposurface under 0 feet
Thu, Apr 6, 2006 at 2:19:20 PM
Dimensions in feet and meters
Tue, Jan 18, 2011 at 7:45:31 AM
Default setting of feet vs. inches
Wed, Dec 19, 2007 at 1:04:53 PM
Page generation time: 0.1396
