Forums >> Revit Structure >> Technical Support >> Inserting a 2D Component into a new project sheet
Thu, Jun 21, 2012 at 1:25:24 PM | Inserting a 2D Component into a new project sheet
ArchCheerios13
I have created a 2D detail component and i have it saved as a family, but i am having difficulty inserting the drawing into a sheet. I have loaded the family into the project but it will not allow me to place the drawing on the the sheet? Help!
Thu, Jun 21, 2012 at 1:28:37 PM | Inserting a 2D Component into a new project sheet
On the sheet?  You mean in a view- right?  I believe this may be your problem.  Try placing it in a model or drafting view.
Thu, Jun 21, 2012 at 1:35:22 PM | Inserting a 2D Component into a new project sheet
ArchCheerios13
Maybe? This was my process, i imported a ArchiCAD detail (DWG file) into a Revit "Detail Item" family (this may have been wrong) then i inserted the DWG into the family file. and saved it as a family. then i went to the main project and loaded the family. The file shows up under the detail item. But when i drag it into the sheet, it gives this error Can't create this kind of element in this view in the current mode." . . . So not sure what i did, maybe ill have to open the DWG as something else othe than a family.
Thu, Jun 21, 2012 at 1:37:26 PM | Inserting a 2D Component into a new project sheet
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do as WWHub stated and place the detail in a drafting view and then place the drafting view onto a sheet.
On the View tab in you project select DRAFTING VIEW, and fill in the information in the New Drafting View dialog box, then find your detail and insert it into that view, then open a SHEET (A101 for example) and drag the drafting view you made onto that sheet.
Edited on: Thu, Jun 21, 2012 at 1:41:29 PM
Thu, Jun 21, 2012 at 1:51:26 PM | Inserting a 2D Component into a new project sheet
ArchCheerios13
Ha! THanks i got the detail into the sheet, But ran into another problem. Not the entire detail was inserted, all of the call out lines and most of the hatching and parts of the actual detail is missing. Its only showing a few dimesnisons and some filled regions.
Thu, Jun 21, 2012 at 1:57:42 PM | Inserting a 2D Component into a new project sheet
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The best practice is to change all of the linework in CAD to layer 0, erase the hatching and then bring the cad detail into the family and explode it, change all of the linework to REVIT lines and replace the erased hatch with FILLED REGIONS, replace the dimensions with REVIT dimensions, save and load it into the project and override the existing.  It may seem like a lot of work but it is the way it should be done.
Bringing actual CAD elements into a project is NOT a good idea.
Edited on: Thu, Jun 21, 2012 at 1:59:06 PM
Thu, Jun 21, 2012 at 2:00:33 PM | Inserting a 2D Component into a new project sheet
ArchCheerios13
Yeah thats what i thought would happen when i was importing all the details from ArchiCAD, if the lineweights would still work. Guess i know now! Thanks teafoe5!
Thu, Jun 21, 2012 at 2:02:26 PM | Inserting a 2D Component into a new project sheet
ArchCheerios13
The company i work for do all of their drawings in ArchiCAD, and they just recently moved to Revit, so im having to move all the stuff into Revit. So thats why i kinda had the problem. Its gonna take some time but i think i got the hang of it. Thanks again
Thu, Jun 21, 2012 at 2:21:57 PM | Inserting a 2D Component into a new project sheet
ArchCheerios13
This is probably another dumb question but how do you add arrows into the details? I looked for them in the the Annotate> Symbols folders but couldnt find an arrow so that way i can point to the material
Thu, Jun 21, 2012 at 2:29:38 PM | Inserting a 2D Component into a new project sheet
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You will need to set up some standards to REVIT and it is going to be different from CAD so its something you and your office will have to get use to.  All of you details that you bring over you should be done with that process to get rid of the CAD elements.
An arrow like from text pointing to an object? Once you create your text you can click on it and under the MODIFY/TEXT NOTES tab (should be highlighted green) under FORMAT you will see an "A" with a + symbol and arrow by it, you can click on either the right or left one to create an arrow on the left or the right side of the text, and the "A" with a - symbol will remove the arrow (be careful because the - will erase them in the reverse order you place them).
If you want an arrow with no text just create a blank annotation family.  Watch the video attached for how to create that.
http://www.youtube.com/watch?v=k44pyzdM1b0
Edited on: Thu, Jun 21, 2012 at 2:31:19 PM
Thu, Jun 21, 2012 at 2:35:41 PM | Inserting a 2D Component into a new project sheet
#11
ArchCheerios13
Yeah i created a text then went to that "A" with an arrow but its not highleted, its grayed out! so ill probably have to just watch the video. Thanks for your help, might as well keep looking back at this thread, ill probably have alot more questions for ya haha
Thu, Jun 21, 2012 at 2:38:23 PM | Inserting a 2D Component into a new project sheet
#12
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How did you create your text? It shouldn't be grayed out.  The video will only show you how to create a leader without text. You don't want to use this unless you need to, its very nice to have the leader attached to the text.
Thu, Jun 21, 2012 at 2:48:11 PM | Inserting a 2D Component into a new project sheet
#13
ArchCheerios13
Im still in the detail family i created, i went to Create> Text> Under Properties i selected New Text> then Edit Type > then i gave it a new name and size. THats all i did, then when i click the text it wont let me select the Text with the leader . . .
Thu, Jun 21, 2012 at 2:55:05 PM | Inserting a 2D Component into a new project sheet
#14
ArchCheerios13
Heres an attachement of what it looks like
Thu, Jun 21, 2012 at 2:56:14 PM | Inserting a 2D Component into a new project sheet
#15
ArchCheerios13
all the existing arrows are from when i imported it from ArchiCAD, so i want to get rid of those
inserting floor plan into sheet
Tue, Feb 28, 2006 at 7:17:46 PM
Inserting Component
Thu, Mar 4, 2010 at 10:46:39 AM
inserting detail component into a beam family
Thu, Feb 22, 2018 at 6:55:27 AM
A guide to inserting profiles?
Thu, Dec 20, 2007 at 4:17:44 PM
Component with text?
Wed, Jun 6, 2007 at 5:26:12 PM
Page generation time: 9.7893
