11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Room tag not showing in only one room.
Thu, Sep 15, 2011 at 1:40:37 PM | Room tag not showing in only one room.
ROBDEVEYRA
Hi:
Im having an issue with room tags.
As I tag the OPEN OFFICE area a warning comes out (please sea attachment). Then I am not able to tag this room- the room tag that says OPEN OFFICE -122 goes away. The room is enclosed but in plan I am not able to tag this room. As you can see theres nothing wrong with the room tags in the other rooms.
The room area is extended to the ceiling so there's nothing wrong with the room volume and I can tag this room in section. The view range is also cut at 4' like the rest of the plans.
Thank you in advance.
Rob
Thu, Sep 15, 2011 at 7:36:16 PM | Room tag not showing in only one room.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hi Rob,
By the sounds of things that particular room is "Hidden by View".  Use the "Reveal hidden elements" (lightbulb) button to turn on everything in the view (should be able to see everything hidden but if its hidden via filter it still won't show).  Select the Room and choose, Unhide element.
HTH.
Regards,
Chris.
Thu, Sep 15, 2011 at 7:53:00 PM | Room tag not showing in only one room.
ROBDEVEYRA
Thanks Mr. Spot.
The room isn't hidden and there are no filters employed in this view.
Whats hidden in this room are lots of office furniture and electrical outlets. I wonder if thats what's causing it.
Rob
Thu, Sep 15, 2011 at 8:25:18 PM | Room tag not showing in only one room.
ROBDEVEYRA
Hi Mr. Spot:
What was causing it was a few(6)  room separation lines that was hidden piled on top of each other in one portion of that room.
I'm grateful for the help. Thanks again.
Rob.
Wed, Sep 19, 2012 at 12:57:56 PM | Room tag not showing in only one room.
lifeisadrift
3.5 Stars: 2 Votes
Problem with a room tag that won’t display, this is what fixed it for me.
Problem brake down:
On my new construction phased plan view all but one room tag would appear. When I would hover over the room with a tag I could see the room name and area total but when trying to tag it I would get an error message. “None of the created elements are visible in: Floor Plan 1 view. You may want to check the active view, its Parameters, and visibility settings, as well as any Plan Regions and their settings.”
So I proceeded to check all the mentioned problems in the error message to no avail. After further investigation I found my problem!
The culprit “Room separation lines”! There was a mix up in the created and demo phase of the room separation lines that were causing the problem to happen.
So make sure to create and demo them on the right phase!
Thu, Jul 21, 2016 at 4:35:15 PM | Room tag not showing in only one room.
Thread Post Kudo! #6
dgorddesign
Just wanted to bump this thread to confirm that the room seperation lines were the culprit for not seeing room tags. I isolated the category with the sunglasses and deleted the offending elements!
Sun, Jun 9, 2019 at 8:46:03 PM | Room tag not showing in only one room.
OctavioNava
Hello to everyone, so i was trying to fin the answer about the room tag not showing and i find that you go on architecture tab-Room and area arrow and in the option area and volume computations you clikc it and in the window that appear you choose AREA ONLY (Faster) then all the new tags will appear, for me that was it. Hope for you to. Good luck.
Fri, Oct 1, 2021 at 11:04:59 AM | Room tag not showing in only one room.
fodongo
@dgorddesign Just wanted to bump this thread to confirm that the room seperation lines were the culprit for not seeing room tags. I isolated the category with the sunglasses and deleted the offending elements!THIS WORKED!! THANKS!!! the room separation lines were buggin and the sunglasses helped! THANK YOU!!
Edited on: Sat, Oct 2, 2021 at 5:50:45 AM
Tue, Feb 11, 2025 at 4:29:06 PM | Room tag not showing in only one room.
katze1104
katze1104 Avatar
A room tag is not showing up in one room in the same view as other rooms that show tags. There are no room separators. The room is higher than the surrounding rooms but I have a ceiling and there is a room within the walls. I can tag it in a section view. I have read previous messages from as far back as 2008. I have tried every scenario and solution and still unable to place a tag in that room. Any help would be greatly appreciated.
Kat
Thu, Feb 13, 2025 at 9:38:13 PM | Room tag not showing in only one room.
Look at where your floor plan cut plane is.  If the raised room is above that, then it will not show.
Sun, Apr 6, 2025 at 9:54:39 AM | Room tag not showing in only one room.
saifkhan
If the room tag isn't showing in just one room, try checking the settings or permissions for that specific room. psl schedule today It could be a display issue or a configuration problem. https://pslschedule2025.com.pk/
Wed, Apr 23, 2025 at 9:51:07 AM | Room tag not showing in only one room.
hvacee
Hi Rob,
Thanks for the detailed explanation — this sounds like a frustrating issue. Based on what you've described, it seems like Revit is having trouble recognizing the room boundary in the plan view, even though the room is enclosed and behaves normally in section. https://windmason.sa/
Mon, Aug 18, 2025 at 7:26:05 AM | Room tag not showing in only one room.
#13
Tasadduq
Turns out room separation lines were the real culprit—hidden layers of them stacked up in that one room prevented the tag from displaying. Removing them did the trick!
Edited on: Mon, Aug 18, 2025 at 4:10:32 AM
Wed, Aug 20, 2025 at 11:13:02 AM | Room tag not showing in only one room.
#14
infotaipan78
TAIPAN78 hadir sebagai salah satu platform game online IDNSPORT terbaik di tahun 2025, menghadirkan pengalaman bermain yang seru, kompetitif, dan tentunya aman.
Sat, Sep 27, 2025 at 3:39:15 AM | Room tag not showing in only one room.
#15
gy56464
Cookie Clicker has revolutionized the idle gaming genre since its creation in 2013. This deceptively simple yet incredibly engaging game has captured the hearts of millions of players worldwide, turning a basic concept into a global phenomenon.
Room not showing
Tue, Mar 25, 2025 at 7:06:37 PM
ROOM TAG TAGS ONLY HALF OF THE ROOM
Wed, May 6, 2015 at 8:58:21 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Room Data Sheet (inc furniture and doors) using a Room Tag
Fri, Jan 20, 2012 at 9:47:21 AM
Page generation time: 1.8814
