Forums >> Revit Building >> Technical Support >> curvy sketch extrusion
Thu, May 5, 2011 at 5:24:27 PM | curvy sketch extrusion
vector23
vector23 Avatar
2 Stars: 16 Votes
see here what i'm trying to do.. i did this extrusion
with spline lines.. but i don't want it to be irregular
like that.. how do i make accurate curves?
Thu, May 5, 2011 at 5:33:01 PM | curvy sketch extrusion
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I would suggest using arcs, still.  Arcs will snap to suggest smooth transitions to the next segment.
Thu, May 5, 2011 at 6:00:13 PM | curvy sketch extrusion
vector23
vector23 Avatar
2 Stars: 16 Votes
huh?
Thu, May 5, 2011 at 6:50:10 PM | curvy sketch extrusion
thetabest
thetabest Avatar
3 Stars: 2 Votes
when you go to draw your shape, there is the little box which has the pick lines, box, etc.  It also has the arc from center, arc from 3 points, etc.  Use either of these to get the shape you desire, splines, as you've noticed, don't allow any true accuracy.
GL
Trent Best
Best Systems
the.tabest@gmail.com
Thu, May 5, 2011 at 7:03:55 PM | curvy sketch extrusion
itsmyalterego
4 Stars: 16 Votes
use start-end-radius arcs.  They will consider the radius of the previous line legment in your path, and snap to suggest a smooth transition.
attached are two pictures, of the snapping of the arc in action, and a sample flashy sweep which I find hard to resist doing.
Thu, May 5, 2011 at 9:32:25 PM | curvy sketch extrusion
vector23
vector23 Avatar
2 Stars: 16 Votes
try again..
Fri, May 6, 2011 at 1:10:09 AM | curvy sketch extrusion
itsmyalterego
4 Stars: 16 Votes
I went out of my way trying to help you.  sorry, I won't try again.   I'm guessing the "gurus" learned this lesson long ago, and that's why there are no other responses.
The "kink" you are seeing is where one portion of the sweep overlaps another.  They're not on the same plane.  The sweep is three tubes, and it's an isometric view.
Edited on: Fri, May 6, 2011 at 1:14:01 AM
Fri, May 6, 2011 at 12:56:13 PM | curvy sketch extrusion
vector23
vector23 Avatar
2 Stars: 16 Votes
of course i appreciate you trying to solve my problem..
my original problem explanation was this:
"i don't want it to be irregular
like that.. how do i make accurate curves?"
you showed my one long curve made with
pieced together arcs.. that leaves kinks and
bends in the thing..
but hang in there- you're doing great.. you
and me partners..
Fri, May 6, 2011 at 1:05:05 PM | curvy sketch extrusion
vector23
vector23 Avatar
2 Stars: 16 Votes
alterego-
the words "try again" was me trying to upload the
image for the third time.. in that image i was pointing
out the "kinks" or bends in the continuous curve- like
what i posted originally with an image showing that
problem..
Fri, May 6, 2011 at 1:27:43 PM | curvy sketch extrusion
thetabest
thetabest Avatar
3 Stars: 2 Votes
how about this?  I'm assuming you can make the shape in CAD, right?  So make a CAD drawing of the shape as you want it, then import it into family, then use the pick lines to draw on top of it (tab click to get most of them at once)... Then delete the CAD import, and because I'm this way, copy linework to another family so that it doesn't have any of the CAD stuff hanging around... Extrude the shape, and hopefully you get what you want...
Trent Best
Best Systems
Fri, May 6, 2011 at 1:41:16 PM | curvy sketch extrusion
#11
Read a geometry book - pay attention to tangential curves.  What alterego showed was correct and all tangential curves.
Fri, May 6, 2011 at 1:54:14 PM | curvy sketch extrusion
#12
itsmyalterego
4 Stars: 16 Votes
Sorry for misinterpreting you.  I was in a bad mood.
Fri, May 6, 2011 at 3:09:04 PM | curvy sketch extrusion
#13
vector23
vector23 Avatar
2 Stars: 16 Votes
Hub- how is it correct if you can see the connection breaks in the
curve and i want a smooth consistant variable radius curve? and
what "geometry" book would you recommend?
Fri, May 6, 2011 at 3:10:42 PM | curvy sketch extrusion
#14
vector23
vector23 Avatar
2 Stars: 16 Votes
alterego- no worries mate- thanks..
Fri, May 6, 2011 at 6:02:33 PM | curvy sketch extrusion
#15
vector23
vector23 Avatar
2 Stars: 16 Votes
thetabest- thanks for trying to help..
i never did CAD or hand drafting- i'm with the new
BIM generation..
How to edit a sketch of Extrusion?
Thu, Aug 1, 2013 at 10:38:11 AM
Curvy roof
Thu, Jun 12, 2008 at 8:36:34 AM
how can we make the curvy facade in revit 2013?
Thu, Dec 26, 2013 at 8:45:11 AM
Sketch a path greyed out...can't alter sweep path
Mon, Jul 26, 2010 at 4:45:05 PM
Sketch up
Thu, Mar 15, 2007 at 6:46:50 PM
Page generation time: 1.9438
