Forums >> Revit Structure >> Technical Support >> Pre-Engineered Metal Building
Mon, Aug 23, 2010 at 11:56:58 PM | Pre-Engineered Metal Building
Craigaleg
Hello! I am a current student that is new to Revit Structural and curious as to the best method to create a Pre-Engineered Metal Building. It has tapered columns and and tapered rafters that vary along 8 grid lines.
I've attached an image of the basic outline of it to give you a better idea of what I am working with. The rafters are not tapered in this picture, but vary in the next few pages, along with the columns. I am curious to know if it would be easier to edit a family type of columns, then rafters and attach them on the floor plan? Or would it be simpler to create one large Pre-Engineered Metal Building unit for each grid line?
Any help would be greatly appreciated, thanks!
Tue, Aug 24, 2010 at 7:12:25 AM | Pre-Engineered Metal Building
Thread Post Kudo! Thread Post Kudo! #2
You can do all of this in Revit - see attached.  The frames I used here were adapted from the frame family that is in the download area.  Please look there.  There are several pre-engineered families there.
Wed, Aug 25, 2010 at 2:48:50 PM | Pre-Engineered Metal Building
Craigaleg
I'm getting a decent start basing off some of the library edits, but for some reason it will not let me edit my members in elevation view. It is stating that it can only edit off something parallel to the member and refers me to the floor/ceiling plan. I've attached the file for reference
Wed, Aug 25, 2010 at 4:07:21 PM | Pre-Engineered Metal Building
It all depends on where / how the shap is created.  Follow what Revit tells you and change views.
Wed, Aug 25, 2010 at 6:59:34 PM | Pre-Engineered Metal Building
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
You can make this ridgid frame from an elevation view and make it exactly like the original and then copy it. I would use the model in place as you are not likely to be reusing this frame. Just create three or four extrusions and you will be done.
Thu, Aug 26, 2010 at 10:32:11 PM | Pre-Engineered Metal Building
Craigaleg
Last problem I seem to be having is forming the tapered rafter.
The rafter ends up tapered on other grid lines. I'm just curious as to the best method of shaping this; should I use a swept blend? Which view is easiest to shape it?
I greatly appreciate all the help you guys are giving by the way. I'm slowly learning how this is all thrown together.
Edited on: Thu, Aug 26, 2010 at 11:34:20 PM
Edited on: Thu, Aug 26, 2010 at 11:34:37 PM
Fri, Aug 27, 2010 at 8:41:45 AM | Pre-Engineered Metal Building
Swept blend would work but most of these are built up just like the actual frame.  Flanges can be sweeps along a path and the web is an extrusion from the elevation view.
Mon, Sep 20, 2010 at 2:54:56 PM | Pre-Engineered Metal Building
arusso5
Does anyone know if there is a pre-fab steel building manufacturer that produces a curved roof?  I'm looknig for a basic Butler building, but with a curved roof, not a low slope gable roof.  Is there anyone that manufactures structures like these?  In real life, not Revit, well okay, Revit too.
Thanks in advance.
Mon, Sep 20, 2010 at 3:22:09 PM | Pre-Engineered Metal Building
I suggest you google this.  There are quonset hut metal buildings that are full curved roof.  Butler and other MBMFG's will also do arched roofs.
Mon, Nov 1, 2010 at 3:03:15 PM | Pre-Engineered Metal Building
Kelsey85
The Pre Eng Model you create WWHub is really great. I am curious how you did that as I am having a hard enought ime jus tinstering girts. Does anyone know of some step by step directions on creating pre eng models?
Mon, Feb 24, 2014 at 11:29:35 AM | Pre-Engineered Metal Building
#11
lcox3
I have a few families like this made already and so far they have been just been for shape and size representation of existing conditions. One of the things that the engineers would like to see is analytics for these families. I am curious if your frames are analytical. If so, was there a great deal of effort put into accurately depicting design criteria?
Mon, Feb 24, 2014 at 12:09:28 PM | Pre-Engineered Metal Building
#12
My frames were NOT analytical and I don't see any reson for them to be.  The pre-engineered manufacturer has specialty programs just not analyse these special shapes.
Wed, Mar 5, 2014 at 11:57:15 AM | Pre-Engineered Metal Building
#13
lcox3
In new construction yes I do not see a point but being able to reanalyze when working with existing buildings that use pre-engineered frames would be very nice. Especially when the the frame engineers are not involved with the rebuild and the client has a tendancy to use them to support additional loads (Which should not be done without reanalyzing since they are usually designed to the bare minimum).
Right now our engineers have to maually build each frame line by line for each frame in our analysis program on top of the designer time modeling the revit frames. I was just curious if there was some way that I could help improve the exports or cut down the time spent with existing frames in general
Wed, Mar 5, 2014 at 5:29:19 PM | Pre-Engineered Metal Building
#14
lcox3
Kelsey85: I have found that puting a referance plane at the top of steel (of your frame) for each direction of slope works great for adding purlins to your roof. If you give the Plane a name then you can switch over to your roof framing plan and set that as your active plane using the work plane toolbar on your home tab. Now simply pick which member you want to use for a purlin and model it in as you would any other beam. I like to cut a section and verify that beams are rotated properly and I will also use the section to check and adjust spacings. Girts are much simpler. Just place the first girt line in plan and copy them up as need
Fri, Mar 28, 2014 at 4:27:44 PM | Pre-Engineered Metal Building
#15
dcarv
Hi all, longtime autocad user but new to Revit and first time post.  I am tasked with trying to bring our metal building company into a BIM / 3D modelling environment from what is a typical 2D Autocad drafting office.  My main goal is to generate 3D drawings with the ability to generate roof details, plans, etc. and have Revit generate metal cladding panel takeoffs with lengths, insulation quantities, thermal clip quantities, fatener quantities, roof panel lengths, gutters, etc.  Basically try to automate much of what is being done now so that it is less tedious and can automate the fabrication issue of the various materials.  We tend to be a bit of a custom manufacturer with different wall & roof configurations from just metal cladding to standing seam roofs at various slopes.  My question for the forum is have I bitten off more than I can chew in embarking on this?  Is anyone currently doing what I am tasked with and have you had success?  I fully expect challenges along the way, require patience and know it will be quite a learning curve but I am hoping to not involve countless hours if in anyones past experiences or efforts state that it is not possible.  I have to believe it is given the complexity of many models that have been done.  I should note that I do not need to detail the structural elements to issue to fabrication with Revit as that is done by a 3rd party outside our office.  I thought I would start by generating common shapes / parts / components that we typically use into a revit format.   Any advice, criticisms, cautions, etc. is greatly appreciated and thank you in advance for any responses.  Cheers all.
Wed, Mar 25, 2015 at 8:01:34 AM
Metal Panels for Pre-Engineered buildings
Thu, Dec 16, 2004 at 12:58:45 PM
Pre-engineered Metal Buildings
Thu, Feb 24, 2005 at 4:37:01 PM
Pre Engineered Buildings Families
Thu, Sep 18, 2014 at 10:59:45 AM
Metal Building
Thu, Oct 20, 2016 at 1:49:19 PM
Page generation time: 0.2557
