Forums >> Revit Building >> Technical Support >> Schedule will not tracj all room names and numbers
Tue, Jul 27, 2010 at 3:46:10 PM | Schedule will not tracj all room names and numbers
squeak
Revit 2009.  I am trying to schedule Cubicle Curtains and Tracks ( Special Equipment Family)  I have got then to schedule by description.  However my Room Names and Room Numbers will not consistently schedule.  Some will some will not. We have door and windows and otherr schedules that show this information consistently
Tue, Jul 27, 2010 at 3:54:58 PM | Schedule will not tracj all room names and numbers
If the item being scheduled does report rooms then your problem could be that the family is not inside a room boundry.
Wed, Jul 28, 2010 at 7:17:47 AM | Schedule will not tracj all room names and numbers
maggielouwho
While that may answer the issue for a couple of areas. The schedule is not picking up any of the first floor rooms. and the cubicle curtains are mostly in enclose rooms.
Wed, Jul 28, 2010 at 7:37:20 AM | Schedule will not tracj all room names and numbers
Remember, rooms also have a height.  Also, if the family has any invisible lines in it, those are considered as part of the family and can cause you problems.  I suggest you try moving the offending family and see what happens.
Fri, Jul 30, 2010 at 11:19:50 AM | Schedule will not tracj all room names and numbers
squeak
I fixed all the room propertires so that the upper limit was to the ceiling this took care of many.  I eliminated the hidden linse . No change
Fri, Jul 30, 2010 at 12:01:02 PM | Schedule will not tracj all room names and numbers
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
A good place to look when things are not showing on a schedule...in particualr for an entire floor is the filters section of the schedule.
Is your scheduled filterd for the second floor or anyting of that nature?
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Jul 30, 2010 at 12:16:17 PM | Schedule will not tracj all room names and numbers
squeak
Thanks but that isn't the issue the cubicle curtain tracks are on the schedule as I want but the Room name and numbers aren't reporting.  There are only cublicle curtains on the first floor of this building.  When  iuse th "show button" for a cubicle cutain without a room name or number it is in a first floor room
Fri, Jul 30, 2010 at 12:36:41 PM | Schedule will not tracj all room names and numbers
brettgoodchild
4 Stars: 17 Votes
base offset in your rooms?
                             ~ Abraham Lincoln
Fri, Jul 30, 2010 at 1:12:30 PM | Schedule will not tracj all room names and numbers
I don't know how your family is built but it is still not in your room.  I have seen floor hosted problems depending on the floor used.  If the host is not in the room, then neither is the hosted element.  Is the family floor hosted and if so, what is your floor?  Are there other families on the same level that do report correctly?  If so, then the problem is probably xy and not z.
Fri, Jul 30, 2010 at 1:41:47 PM | Schedule will not tracj all room names and numbers
squeak
They are in there because it is showing up in the schedule.  The room name and number are not .  The problem is occuring in only 50 % of the rooms in this building and  I have been able to get the complete schedule in the other buildings on the campus
Fri, Jul 30, 2010 at 1:54:06 PM | Schedule will not tracj all room names and numbers
I understand the items are in the project.....   I am saying they are not fully in the room.
As brett said, the problem could be the bottom of the room as well.  And as I said, some floors act differently and are identified from their bottom and others are from the top.  Floor hosted items on bottom ID floors will not show up.
Depending on the family's insertion point, exterior wall hosted items may also not be identified in the space.  You can play with these families in a test project moving the room limits arond to see what happens.
Fri, Jul 30, 2010 at 2:03:59 PM | Schedule will not tracj all room names and numbers
squeak
they are ceiling based families and the ceilings schedule
Fri, Jul 30, 2010 at 3:42:51 PM | Schedule will not tracj all room names and numbers
#13
brettgoodchild
4 Stars: 17 Votes
Could you post the family(s) for us to look at?
                             ~ Abraham Lincoln
Fri, Jul 30, 2010 at 3:55:32 PM | Schedule will not tracj all room names and numbers
#14
squeak
Unfortunately Not the files are from and associate architect and I do not have access to their Library
Fri, Jul 30, 2010 at 3:57:59 PM | Schedule will not tracj all room names and numbers
#15
squeak
Just figured out the work around
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Abbreviating Room Tag Names vs. Schedule
Thu, Sep 1, 2011 at 2:05:14 PM
Room names/numbers
Wed, Nov 21, 2018 at 1:00:24 PM
Room Schedule not updating
Fri, Feb 15, 2008 at 3:42:27 PM
Room names Not showing in Schedule [ 1 2 ]
Tue, Jul 24, 2012 at 7:05:38 AM
20
Page generation time: 0.2989
