Forums >> Revit Building >> Technical Support >> import label anootation to generic 3d model
Sun, Jul 4, 2010 at 6:56:29 AM | import label anootation to generic 3d model
raephael
i am trying to adapt the revit family Ladder to make a stud wall where rungs and stud have similar parameters
but
the "number of rungs" label is snagging me,how  do incoperate it in a 3d model
load family into generic model restricts import-excludes annotation label?
see clip for explanation
http://www.youtube.com/watch?v=qri7zaH02x8
shared parameters?
Sun, Jul 4, 2010 at 8:42:50 AM | import label anootation to generic 3d model
4 Stars: 205 Votes
That "number of rungs" is the parameter from the "Array, after you create the array, select one element then select the line with the number (2), in the options bar select "Label / Add parameter", then give it a name (number of rungs), and a group parameter like you can see in the images.
Sun, Jul 4, 2010 at 1:16:17 PM | import label anootation to generic 3d model
raephael
i think i understand the quantitiyparameter but the use of it in a 3d template family is the problem
it works in 2010 version but not in 2009?
label with number (quantity properties) -right klik- edit label and your off
but not in 2009? (or have i missed somthing-i dont get the option edit label in 3d template family in 2009)
see (1000 words) clip
http://www.youtube.com/watch?v=8NfO5iS2yeE
Sun, Jul 4, 2010 at 3:30:17 PM | import label anootation to generic 3d model
raephael
could some one please explain?
the url captured the right click edit label add parameter fuctioning in revit 2010
so i thought it was a 2010 update problem
now it(revit2010)refuses to right click edit label as shown in clip
it was ok earlier today now its not allowing right click edit label?
can i blame the tools?
Sun, Jul 4, 2010 at 11:40:49 PM | import label anootation to generic 3d model
raephael
SELECTION PROBLEM
click one item in array and right click number of array and you will not get the edit label option
drag and  click all items in array and it works
http://www.youtube.com/watch?v=MuT3QK7bYOQ
thanks
yuor wellcome
dont mention it
Mon, Jul 5, 2010 at 5:26:19 AM | import label anootation to generic 3d model
4 Stars: 205 Votes
No need that, you must SELECT the LINE of the array and not the number, watch this: http://screencast.com/t/NzFkYTlm
Wed, Jul 7, 2010 at 6:36:52 AM | import label anootation to generic 3d model
raephael
thank you
Thu, Aug 12, 2010 at 5:57:58 AM | import label anootation to generic 3d model
raephael
hi
perhaps you can throw light on the following
door swing problem
the family crane/logistics/site  has a boom angle parameter that moves the boom. a simple extrusion
i and trying to copy this into a door swing but find i over constrain or lose the shape of door
i found sweep worked better than extrude but still run into problems attaching hinges to door
perhaps it is to do with the site template but in the site template(building a wall and door) it does not work for me either
the url shows the question better--trying to copy the boom swing parameter but running into problems
Thu, Aug 12, 2010 at 6:03:01 AM | import label anootation to generic 3d model
raephael
the above is another clip of the same problem
Thu, Aug 12, 2010 at 1:26:38 PM | import label anootation to generic 3d model
4 Stars: 205 Votes
Ok, watch this: http://screencast.com/t/NTNjZDRh
Fri, Aug 13, 2010 at 3:54:06 AM | import label anootation to generic 3d model
#11
raephael
it does not flex very well?
i find it very difficult to repeat what is on the video
the extrusion starts with 2 locks on the first line--i cant get that --as soon as i move cursor the locks banish
perhaps thats the problem
all attempts lead to remove constraints (on 1 lock)
is that a tutorial seris?
thanx
Fri, Aug 13, 2010 at 4:05:22 AM | import label anootation to generic 3d model
#12
4 Stars: 205 Votes
"the extrusion starts with 2 locks on the first line--i cant get that --as soon as i move cursor the locks banish perhaps thats the problem"  - That's because when you are creating the line, first you may uncheck the "CHAIN" mode in options bar, when you do that you can lock those padlocks.
 "is that a tutorial seris?" - NO, i create that video just for you.
Fri, Aug 13, 2010 at 9:04:12 AM | import label anootation to generic 3d model
#13
raephael
thanks a lot for the clip
i s am still struggling with it
need to look at basic constraining and dims again
still comes up remove constraints-extremely fragile
http://www.youtube.com/watch?v=LJ7irIs4cEU&feature=channel
Fri, Aug 13, 2010 at 3:33:52 PM | import label anootation to generic 3d model
#14
4 Stars: 205 Votes
Ok, watch this: http://www.megaupload.com/?d=S8U8EPLM
Sat, Aug 14, 2010 at 3:19:14 PM | import label anootation to generic 3d model
#15
raephael
thanks again for your help
very explicit
i think the problem to some extent is the tools
why is it so difficult to snap point on ref line in dim mode
a lot of what needs to be learned seem to be a case of trial and error approach
their is no documentation that i know explaining these problems?
thanx again /youve been very helpfull
Import model from AutoCAD
Fri, Jul 9, 2010 at 11:31:27 AM
Label - Generic annotation - parameters
Thu, May 17, 2007 at 10:03:54 AM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:18 PM
Generic Annotations - Hiding Labels
Wed, May 16, 2007 at 4:17:31 PM
Generic Model Materials
Wed, May 18, 2005 at 5:03:38 PM
Page generation time: 1.7692
