Forums >> Revit Building >> Technical Support >> Step by step of exporting revit model to 3dsmax for render (Vray)?
Sun, Jun 6, 2010 at 10:29:26 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
mrbeandiesel
mrbeandiesel Avatar
1.5 Stars: 4 Votes
Hi!
  I have a RAC2010 64-bit and i want to render it to 3dsmax2010 64-bit, a simple interior room would be nice to begin with as an example, I already searched and tried earlier steps of it like opening the interior scene view ready for render and export it to FBX file->open 3dsmax-> import..and i'm stuck i dont know the next step for it.
PS: I already installed Vray for its method of rendering....
I would understand any explanation on this thread or simply links that helps on this query is highly appeciated
Thank you in advance!
Sun, Jun 6, 2010 at 10:33:05 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
mrbeandiesel
mrbeandiesel Avatar
1.5 Stars: 4 Votes
After importing and FBX file from revit i dont know what would be next begining from selecting presets right after importing...
Mon, Jun 7, 2010 at 1:13:04 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Revit and Autodesk FBX are not Vray compatible. Once you import the FBX you must change all the materials and erase the photometric lighting and replace it with vray lighting.
Mon, Jun 7, 2010 at 3:12:19 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"Revit and Autodesk FBX are not Vray compatible." Hmmmm....alabaster, depends on the version, VRay 1.5 SP4 is now compatible with Revit & Autodesk FBX files.
Mon, Jun 7, 2010 at 7:49:27 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
alabaster2513
3.5 Stars: 25 Votes
Whatchu talkin bout Ernesto!?!?! It uses MR materials and photometric lighting? I abandoned Vray a while ago. you got a trial of SP4?
Mon, Jun 7, 2010 at 8:29:52 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
mrbeandiesel
mrbeandiesel Avatar
1.5 Stars: 4 Votes
BTW i have a registered V-Ray Adv 1.50.SP4 installed..
What should i select next?  Autodesk Architectural (Revit) or Autodesk Media & Entertainment?
Please tell me what's the difference between the two options and what is preferable to select,
Please see image below.
Thank you for any help you can suggest...
Mon, Jun 7, 2010 at 8:36:56 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
mrbeandiesel
mrbeandiesel Avatar
1.5 Stars: 4 Votes
I already tried the two options but i'm still clueless about which to choose, please guide me until it renders to vray..
I'll just keep practicing at the moment waiting for a helpful reply
Thanks
“Learning never exhausts the mind.”  — Leonardo Da Vinci , erland73 :D
Mon, Jun 7, 2010 at 11:20:14 PM | alabaster2513
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Quoting alabaster2513 from 2010-06-07 19:49:27
alabaster, the first image was render in Revit (0:09:36 Medium 300 DPI), the second one is the .fbx file imported into Max 2011 and rendered with VRay 1.5 SP4 (0:01:30 Medium). I just rendered the model (I mean, I didn't apply new materials on it). Well, as you can see the only material that is not compatible is the glass, but in anyway........and yes, the lighting fixtures imported, work as well....
Edited on: Mon, Jun 7, 2010 at 11:37:48 PM
Mon, Jun 7, 2010 at 11:46:31 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
mrbeandiesel
mrbeandiesel Avatar
1.5 Stars: 4 Votes
Hope you're not arguing..:p
Sir Ernesto , can you please tell the process you did from revit to max, i really wana learn it, just enumerate it the simplest way you could and i'll be the one to explore, i just wanna know the basic like you just did in the picture...
Clever as always my friend..
Tue, Jun 8, 2010 at 1:37:17 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
alabaster2513
3.5 Stars: 25 Votes
mrbeandiesel,
First i would suggest downloading the latest FBX plugin, check your webupdates button on the import dialogue.
Tue, Jun 8, 2010 at 9:08:47 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
mrbeandiesel, about the fbx thing, maybe this could be useful for you.....
Edited on: Tue, Jun 8, 2010 at 9:10:01 PM
Wed, Jun 9, 2010 at 2:06:05 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
alabaster2513
3.5 Stars: 25 Votes
are you using vray alot ernesto? i just got sp4 and started messing with it. i havint used vray in a few years so i'm having to relearn it Sad
Wed, Jun 9, 2010 at 2:47:35 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
#13
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"are you using vray alot ernesto?" Not really,Matt....depends on the client. I'm trying with Fryrender nowadays. Easier to set up....
Edited on: Wed, Jun 9, 2010 at 8:11:19 PM
Wed, Jun 9, 2010 at 3:17:07 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
#14
alabaster2513
3.5 Stars: 25 Votes
yeah i tried just opening a revit fbx and hitting render on vray, looks kinda wierd
Wed, Jun 9, 2010 at 6:25:47 PM | Step by step of exporting revit model to 3dsmax for render (Vray)?
#15
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Yeah, it seems that although it preserves the materials from Revit, it loses some settings (brightness,etc.)
Step by Step Guides to Buildings
Sun, Dec 7, 2014 at 7:57:47 AM
Revit to 3Dsmax vray glass problem
Tue, Jan 21, 2014 at 8:47:01 AM
Step-by-step to finish
Tue, Dec 9, 2014 at 3:32:52 PM
step in wall
Fri, Oct 16, 2009 at 7:31:09 AM
basic window family tutorial(step by step)
Mon, Sep 6, 2010 at 7:26:53 PM
Page generation time: 1.8288
