Forums >> Revit Building >> Technical Support >> Tape Measure Properties
Mon, Oct 3, 2005 at 6:57:52 AM | Tape Measure Properties
Nathan
4.5 Stars: 3 Votes
I am running a version of Revit 8.1 and have a query with the tape measure option. When using the feature the measurement displayed is too small to read. Is there any way of increasing the size of the text displayed.
Mon, Oct 3, 2005 at 4:35:09 PM | RE: Tape Measure Properties
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yeah i've noticed that a few times. It's indicative of the scale of the view. There is no way to adjust this size. I typically just zoom in on it til i can read it...
Tue, Oct 23, 2007 at 1:20:55 PM | Tape Measure Properties
JHanby
3.5 Stars: 3 Votes
Is there a way to change the units to the tape measure?  I put my setting for the model to 1/8" but the tape measure still gives me units of 1/256"  Version 9.1
Tue, Nov 6, 2007 at 10:38:21 AM | Tape Measure Properties
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
 I'm trying to get in the habit of looking in the option bar for the measurement when the text is covered up by other lines or is very small. That way I don't waste time zooming way in and then back out again every time. Every little efficiency helps.
The tape measure precision posed by JHanby is the question that I was actually searching for. I personally like the high precision ...perhaps a  512th would be twice as good for me, because I like to see right away if something is off even very slightly. I, however, have had this question posed by another person in the office, and I said that I would check on it. I assume they aren't fans of estimating reduced fractions. I hope the answer is that this is not adjustable...just doing my due diligence.
Thu, Jun 26, 2008 at 9:48:12 AM | Tape Measure Properties
Archimatt
I would like to revive this question.  I have been searching the forums here and I want to know the same thing.  I think 1/256 is a little rediculous for accuracy.  I want to find a way to change it to 1/8, thats really all the contractors care about, and thats all I care about.
I have gone through most if not all of the selections under settings and have changed everything that I can find relating to dimensions.
How do we change the measuring tape units?  Please help!  :-)
Thanks
Thu, Jun 26, 2008 at 10:28:59 AM | Tape Measure Properties
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
The contractor won't care about your tape measure at all unless he's standing over your shoulder watching you Revit. Tape measure and dimensions are two different things. If you successfully changed the precision of your tape measure to 1/8" then something can be off by 15/256" and you'd never know. Copy/array that inaccuracy down the side of a building a couple dozen times and suddenly your overall dimension and the total of your intermediate dimensions are an inch and half different. Now there's something the contractor will care about.
Thu, Jun 26, 2008 at 10:41:36 AM | Tape Measure Properties
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
<Duplicate Deleted>
Edited on: Thu, Jun 26, 2008 at 10:42:05 AM
Thu, Jun 26, 2008 at 11:07:10 AM | Tape Measure Properties
lunchtrayrider
3.5 Stars: 7 Votes
if you want your temporary dimensions to be bigger then here is how you do it:
1. find your revit.ini file (location will varry depending on installation
 2. open it. (notepad)
 3. scroll down to [Graphics]
4. under [Graphics]   add the line TempDimFontSizeInPoints=14 (where the 14 is the size in points of the numbers. revit is generically 8 so anything bigger then that will make the text bigger.)
it should look like
 [Graphics]
5. close and save.
6. restart revit.
7. temp dimensions are bigger. I usually use 10 pt font. 14 makes it obviously bigger.
I like scooters. and motorcycles.
Thu, Jun 26, 2008 at 11:20:08 AM | Tape Measure Properties
Archimatt
Thanks, but what I'm really after is where I can find the settings to adjust the properties of the measuring tape function so that its tolerance is set at 1/8" and not 1/256".
Thu, Jun 26, 2008 at 11:26:12 AM | Tape Measure Properties
lunchtrayrider
3.5 Stars: 7 Votes
sorry missed the total thread hijack.  anyway i guess my post applies to the OP.
Thu, Jun 26, 2008 at 11:32:51 AM | Tape Measure Properties
#11
Archimatt
Thu, Jun 26, 2008 at 11:55:29 AM | Tape Measure Properties
#12
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
hey trayrider, why's your ranking so low? I don't remember you being particularly unhelpful in other threads. I'm throwing a 5 your way. the fact that you provided the answer to the OP is of more value than my random opinion on the tangential nonsense in here.
Thu, Jun 26, 2008 at 12:04:01 PM | Tape Measure Properties
#13
lunchtrayrider
3.5 Stars: 7 Votes
i make smart-a$$ coments sometimes that i'm sure people take the wrong way.
Fri, Dec 3, 2010 at 1:48:09 PM | Tape Measure Properties
#14
jalegard
Hello All,
Was there ever an answer to this question that was posted early in the thread - "Is there a way to change the units to the tape measure?  I put my setting for the model to 1/8" but the tape measure still gives me units of 1/256".
Thanks.
Fri, Dec 3, 2010 at 1:58:05 PM | Tape Measure Properties
#15
gdoherty0102
3 Stars: 2 Votes
I do not think there is a way to change this... The tape measure tool is supposed to be the highest accuracy tool in the program so thats why it goes to 256.
If your tape gives you a measurment of 30' - 0 1/256" grid to grid and you want it to be 30'...why fix it at make it 30' - 0"?  Why not model things accuratly rather than rig the tools to show you want to see?
I am surprised to see this many people using the tape measure tool... I have been using revit since RB5 and have maybe used that tool a dozen times, so just curious when do you use that tool?
tape measure tool doesnt work in elevation
Wed, Jan 12, 2011 at 1:19:04 PM
small dimension box & tape measure dimension
Sat, Sep 20, 2008 at 5:05:53 PM
measure tape in section doesn work
Tue, Mar 15, 2011 at 5:37:48 PM
How to change the number size on the tape tool and on the cursoe
Sat, May 1, 2010 at 4:46:44 AM
4 qusetions from a newbie REPOST
Fri, Feb 6, 2009 at 12:45:50 PM
Page generation time: 0.5362
