Forums >> Revit Building >> Technical Support >> No Lines?
Sun, Feb 14, 2010 at 5:41:38 AM | No Lines?
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
does no model lines mean no curtain walls in openings?
Sun, Feb 14, 2010 at 6:50:40 AM | No Lines?
4 Stars: 205 Votes
I answer this question in other thread you post....
Edited on: Sun, Feb 14, 2010 at 6:58:26 AM
Sun, Feb 14, 2010 at 6:53:08 AM | No Lines?
Kardiff
5 Stars: 3 Votes
lines is greyed out because your in 3D view
if you look on your left on your ribbon, you'll notice lines are also greyed out there, is the same command
go into a plan view and draw your lines there
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Sun, Feb 14, 2010 at 5:15:06 PM | No Lines?
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
both of you are answering the wrong question..
i am NOT asking about lines with the ribbon..
i am asking about lines with the classic..
here is the image again- notice this is NOT
the ribbon..
Sun, Feb 14, 2010 at 7:08:24 PM | No Lines?
I really don't understand why you are fighting the ribbon.  I really believe it is so much better than the classic.  And in this case, the classic just might not be working.
Sun, Feb 14, 2010 at 8:10:00 PM | No Lines?
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks Hub-
you say you can't understand why i'm fighting the ribbon..
can you understand why polls show nearly half of revit
users are using the classic?  how many would be
using the classic if it had model lines and shortcut keys
and didn't give multiple error messages everytime you
closed it?.. not to mention all the other things that are
not working properly with it.. it seems pretty obvious
to me that OVER half would be using the classic if it
worked properly..
no need for me to go into all the reasons why the
ribbon does not perform as well as the "native" UI-
but can you connect any of these facts with logic
and then understand it?
the ribbon with AutoCAD is the same idea- but autodesk
allowed the classic to funtion PROPERLY on that program-
and do you have any idea how many AutoCAD users use
the ribbon these days? nearly none.. don't you wonder why?
the factory stated that they made a mistake forcing the ribbon
on revit users before they got it right.. i wonder who autodesk
thought they were selling this program to- themselves?
but logic is not popular these days so if you feel a certain way
then that's fine..
i'm just praying they don't make the same mistake twice and
force anything on us for revit 2011.. otherwise i will have to uncover
all the possible workarounds there are and  stay with 2010..
and that will mean being part of a SEPARATE industry based
on RAC 2010.. and there are PLENTY of us.. and of course that
would also open the door for some software company to start
building the ultimate BIM program..
Mon, Feb 15, 2010 at 1:53:02 AM | No Lines?
Kardiff
5 Stars: 3 Votes
sorry when i said ribbon I meant the left column your baiscs 'tab'that also has lines greyed out
the command is independant to the curtain walling command
Mon, Feb 15, 2010 at 3:57:51 AM | No Lines?
4 Stars: 205 Votes
WYS1WYG, this issue about the ribbon was several times discuss here in the forum, Autodesk said everyone can change the U.I. but: "It is possible to enable the Revit 2009 user interface in a Revit 2010 product, but no support will be provided for problems that occur in that environment that are not reproduced in the standard 2010 user interface."
Mon, Feb 15, 2010 at 4:44:58 AM | No Lines?
4 Stars: 205 Votes
WYS, it better be a little polite, don't you think? With attitudes like this will not help you at all.... belive me.....
"the ribbon with AutoCAD is the same idea- but autodesk
the ribbon these days? nearly none.. don't you wonder why?"
BTW, i use Autocad since 1990, start with version 9 in DOS, now i still use Autocad Civil 3D 2010 and i use the Ribbon.
Edited on: Mon, Feb 15, 2010 at 5:07:56 AM
Mon, Feb 15, 2010 at 5:03:40 AM | No Lines?
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Typhoon- telling my that autodesk doesn't support the
classic UI was rude and YOU KNOW IT.. and you know
I KNOW IT..  and what's AutoCAD got to do with anything..
wow you sure know a lot about revit for a CAD monkey- lol
anyway- i can easily switch over to the ribbon on those
occasions when i need model lines.. so please tell me
why i'm not seeing "curtain system by line" on the ribbon?
BTW- that ribbon is pretty that's for sure.. lol
Mon, Feb 15, 2010 at 5:18:44 AM | No Lines?
#11
Whoa!  WYS1WYG ....
What Typhoon posted is in no way rude or disrespectful because it comes straight from AutoDESK.  AutoDESK only supports the ribbon - period.  Sorry, but if you use the classic it is at your own risk.
I also don't know where you get your numbers for classic vs ribbon users.
Mon, Feb 15, 2010 at 5:43:26 AM | No Lines?
#12
4 Stars: 205 Votes
From the CAD MONKEY, see the video and turn on the sound: http://screencast.com/t/NmFkZDU1Ym
Mon, Feb 15, 2010 at 6:02:45 AM | No Lines?
#13
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Hub- you can't lie to me.. lol
and i don't really care about any numbers..
i just know i'm happy right now because if
2011 doesn't have the classic i can just
do my model lines by switching over to the
ribbon just for that.. and it's not very often i need
model lines anyway.. but that IS a workaround..
and that's all i needed..
Hub- just to prove how worthless this ribbon is-
just wait until 2011 and see how radically they
have changed it.. you'll see.. an who knows- maybe
i'll like it myself- lol..
for sure you will have to learn the new UI all over
again- when logic would have told you to stay with
the classic (model lines or not) until they got it right..
even Eddy Krygiel co-author with Tatjana Dzambazova
former revit product manager is selling classic UI T-shirts
with their new Mastering Revit Architecture 2011 book..
i'm sorry you don't get it Hub- but it's okay- no big deal..
Mon, Feb 15, 2010 at 6:07:43 AM | No Lines?
#14
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Typhoon- i didn't see any model lines
in your video.. and that's all i've been
talking about is model lines and curtain
system by line..  oops- lol..
Mon, Feb 15, 2010 at 6:29:15 AM | No Lines?
#15
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
does anyone know if the ribbon has "curtain system by lines"
like the classic UI has? if it does and you know where they
are- please tell me..
thanks..
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Lines plotting half toned
Fri, Jun 15, 2012 at 10:42:01 AM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Page generation time: 0.3348
