Forums >> Revit Building >> Technical Support >> Faceting a Revolve instead of Smooth Result
Tue, Jun 2, 2009 at 12:48:08 PM | Faceting a Revolve instead of Smooth Result
j9design
Anyone know how I am able to get a revolved object to actually have faceted surfaces instead of a perfect circular revolve?  I want it to go all 360 degrees around but want some facets to the object.
Tue, Jun 2, 2009 at 12:59:27 PM | Faceting a Revolve instead of Smooth Result
Do it in Cad revsurf and set your surftabs then import.
Tue, Jun 2, 2009 at 1:21:48 PM | Faceting a Revolve instead of Smooth Result
4 Stars: 205 Votes
OR you can create that in the new conceptual mass if you are working in 2010, of course...
Tue, Jun 2, 2009 at 1:33:00 PM | Faceting a Revolve instead of Smooth Result
j9design
new conceptual mass seems the way to go if you can add  material to that.  So far, I can't find any way or source that explains how to add material to a dwg file so importing from cad won't work I think.
Tue, Jun 2, 2009 at 1:37:10 PM | Faceting a Revolve instead of Smooth Result
4 Stars: 205 Votes
If you create that in CAD, then you can apply walls, roofs, slabs and curtain system by face where you can choose the material you want....
In 2010, with the new conceptual masses you can do the same OR create some families (panels) with the material you want and apply to the model....
Tue, Jun 2, 2009 at 4:04:28 PM | Faceting a Revolve instead of Smooth Result
lunchtrayrider
3.5 Stars: 7 Votes
find a piece f wood.  apply to forehead repeatedly.  make big oversized family. (if your using 2009)
Tue, Jun 2, 2009 at 5:53:28 PM | Faceting a Revolve instead of Smooth Result
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
array
Tue, Jun 2, 2009 at 7:14:38 PM | Faceting a Revolve instead of Smooth Result
j9design
thanks for taking up some of your time in your busy life to post such a beneficial comment, lunchtrayrider.  I'm just learning the program as I go and started using it about a month ago, in 2010, without any help other than internet forums, so again, glad you could waste some of your precious time on such a great forum troll comment at my post.  Keep up the productive effort!
Tue, Jun 2, 2009 at 7:27:12 PM | Faceting a Revolve instead of Smooth Result
j9design
Where can I find the forehead component in Revit?
Tue, Jun 2, 2009 at 10:58:54 PM | Faceting a Revolve instead of Smooth Result
j9design
an image of the object i'm trying to create to bring material to it.  I brought it in from 3ds, exporting it as a dwg file.  The object doesn't accept the paint tool and is not considered a solid object since 3ds doesn't make objects like revit does.  What is the best way for me to either recreate this object in revit, or add a material to a dwg file that was inserted?  Thank you in advance to anyone willing to provide the answer.
Wed, Jun 3, 2009 at 6:41:52 AM | Faceting a Revolve instead of Smooth Result
If this object is now 3D dwg, you can assign materials to it by layer. In the project - settings/object styles - imported objects tab.  Fid the dwg - expand it so that you can see the layers - now assign your materials.
Wed, Jun 3, 2009 at 8:58:18 AM | Faceting a Revolve instead of Smooth Result
lunchtrayrider
3.5 Stars: 7 Votes
i've never tried wwhubs way but is there any reason you just couldn't build that object in revit?
Wed, Jun 3, 2009 at 9:00:29 AM | Faceting a Revolve instead of Smooth Result
#13
lunchtrayrider
3.5 Stars: 7 Votes
does it have to be just surfaces or one big solid?
Fri, Jun 5, 2009 at 10:52:53 AM | Faceting a Revolve instead of Smooth Result
#14
j9design
i assume there is a way to build it in revit, but I'm not sure how to go about it.  I tried the settings, layer material option and that had no effect.  I was thinking the easiest way to build it would be to just revolve the faceted profile 360 degrees and changing it to be more like an 8 on the revsurf in cad, but I don't know how to access an option similar to that in revit.  If you have another way to build it, I'd love to have it explained.
Fri, Jun 5, 2009 at 11:25:07 AM | Faceting a Revolve instead of Smooth Result
#15
tim123
4 Stars: 19 Votes
I can't quite make out the shape, but it would appear that you could create that from two blends.
Solid Revolve
Thu, Jan 13, 2005 at 10:28:58 AM
using revolve tool to shape top of walls 'Revit 2012'
Wed, Feb 20, 2013 at 2:47:55 PM
Revolve along a curved axis?
Tue, Apr 1, 2008 at 3:40:01 PM
Why the bad quality in family models?
Fri, Jan 22, 2010 at 9:20:41 AM
Revolve Axis
Wed, Mar 29, 2006 at 2:46:10 AM
Page generation time: 0.1108
