Forums >> Revit Building >> Technical Support >> Tranparent sweeps?
Thu, May 7, 2009 at 8:39:36 AM | Tranparent sweeps?
Studioe
I've been attempting to use the sweep function to create a cornice around the top of a building (and other things), however the finished product ends up transparent with no shadows cast (see image).
Suggestions?
Thu, May 7, 2009 at 8:48:20 AM | Tranparent sweeps?
tim123
4 Stars: 19 Votes
Are you doing it as a mass?  If so, rather create the component in a category, such as walls.
Thu, May 7, 2009 at 8:52:54 AM | Tranparent sweeps?
Studioe
Hmm. I'm using the host sweep function under the modeling tab. Is there a way to do it as a wall?
Thu, May 7, 2009 at 8:56:08 AM | Tranparent sweeps?
tim123
4 Stars: 19 Votes
If you go into the sweep properties you can set the material there.
Thu, May 7, 2009 at 8:57:19 AM | Tranparent sweeps?
Studioe
I had to use a Mass to get the curved roof you see in the image, which was doing the same thing.
Thu, May 7, 2009 at 9:00:52 AM | Tranparent sweeps?
tim123
4 Stars: 19 Votes
I would have created the curved roof as a roof and not a mass.  You can model it in the same way that you did the mass.  Create an in-place component and give it the roof category.
Thu, May 7, 2009 at 9:02:17 AM | Tranparent sweeps?
Studioe
If I right click and go into element properties, I get this without the ability to change materials.
Thu, May 7, 2009 at 9:04:24 AM | Tranparent sweeps?
Studioe
Yeah, I should have done that. Maybe I'll rebuild teh curved roof.
Thu, May 7, 2009 at 9:04:27 AM | Tranparent sweeps?
tim123
4 Stars: 19 Votes
Go to the element properties and click on 'edit type'.
Thu, May 7, 2009 at 9:12:28 AM | Tranparent sweeps?
Studioe
these are the options - I don't see 'edit type'
Thu, May 7, 2009 at 9:14:45 AM | Tranparent sweeps?
#11
Studioe
Wait - I get whqat you're saying - this is the dialogue that shows up...
Thu, May 7, 2009 at 9:18:21 AM | Tranparent sweeps?
#12
Studioe
Thu, May 7, 2009 at 9:21:13 AM | Tranparent sweeps?
#13
tim123
4 Stars: 19 Votes
OK, this confirms that it was created as a mass and not a hosted sweep.  Do it as a wall hosted sweep, or as an in-place family in the wall category.  You can change the appearance of the default mass material in the material settings, but I would not use a mass for this.
Thu, May 7, 2009 at 9:38:19 AM | Tranparent sweeps?
#14
Studioe
OK..
The wall sweep and wall reveal are grayed out in plan view.
The are accessible in 3D view, but I'm not given the option to create a profile.
If I apply it using the default profile (rectangular profile), it seems like I can then modify the profile, but I guess I need to create and save a profile somewhere.
Thu, May 7, 2009 at 9:46:00 AM | Tranparent sweeps?
#15
tim123
4 Stars: 19 Votes
There are two options.  A wall hosted sweep as you suggest requires a profile to be loaded.  You need to create that first and then load it into the project (use the Profile hosted template).  The second option, which you can do in a plan view is to create a component in place, using the wall category, define the path and draw the profile that you want.
color scheme with tranparent solid fill
Tue, Dec 27, 2011 at 1:32:03 PM
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Can you rotate wall sweeps?
Wed, May 2, 2012 at 9:23:44 PM
Page generation time: 0.0548
