Forums >> Revit Building >> Technical Support >> Revit 2010 Printing Problems
Thu, Apr 30, 2009 at 10:32:48 AM | Revit 2010 Printing Problems
Legobusier
We just upgraded to 2010, so far so good, but I noticed this am that our company logos (image files on our sheets) were not printing..
 If I load the logo RIGHT on the drawing sheets (in the project file) they print, but not when loaded on the sheet family....any suggestions?
Thanks,Chris
Wed, May 6, 2009 at 10:25:22 AM | Revit 2010 Printing Problems
Cooolness
I have the same problem.  It used to work in 2009 but for some reason it does not work 2010.
Wed, May 6, 2009 at 12:28:48 PM | Revit 2010 Printing Problems
Mine prints - just doesn't show up in the preview.
Wed, May 6, 2009 at 1:21:45 PM | Revit 2010 Printing Problems
Cooolness
What are your print settings?
Wed, May 6, 2009 at 2:10:03 PM | Revit 2010 Printing Problems
It has nothing to do with print settings but if you are having problems, it could be that you don't have the latest drivers.
Wed, May 20, 2009 at 3:38:36 PM | Revit 2010 Printing Problems
Cooolness
I have updated my drivers and still no luck.  Autodesk knows about the problem and plans on fixing it in their next sevice pack.
Tue, Jun 2, 2009 at 8:54:54 AM | Revit 2010 Printing Problems
RevitSVA
RevitSVA Avatar
Also having serious problems with crashing....
Upgraded drivers, did the 3gig switch, etc, etc... seems like 2010 has significant errors....
If you receive any tips on getting solutions for it please post it urgently!!
Tue, Jun 23, 2009 at 3:21:09 PM | Revit 2010 Printing Problems
CDYER36
5 Stars: 4 Votes
I'm having issues with printing my rendered sheets. They look fine on the screen, yet print out backwards and upside down??? Anyone with some suggestions on this??
Tue, Jun 23, 2009 at 3:29:56 PM | Revit 2010 Printing Problems
Is your print driver the latest...?
Perhaps you should list the printer and you may get a better response.
Wed, Jun 24, 2009 at 5:41:34 AM | Revit 2010 Printing Problems
RevitSVA
RevitSVA Avatar
Revit 2010 has a issue with JPG, JPEG formats and battle or crashes when printing
We noticed the problem when our logo kept on dissapearing of our sheets and allot of crashes in the office when we were doing coneptual design with jpg etc.
Change images to tiff format and it should be resolved.... it helped us, apparently it is a known issue
Wed, Jun 24, 2009 at 7:17:39 AM | Revit 2010 Printing Problems
#11
MARS1276
1 Stars: 1 Votes
I tried using the option for the hardware acceleration, and while it worked good in plan and model views; it would crash when I went to print.  It wasn't too friendly when panning within a sheet drawing either.  So I turned off the hardware acceleration and haven't had any trouble printing since.  Are you having this problem?
Wed, Jun 24, 2009 at 7:47:47 AM | Revit 2010 Printing Problems
#12
CDYER36
5 Stars: 4 Votes
I'm using a HP color inkjet printer cp1700 and i tried to pdf the sheet to see if i could print that out instead, but it crashed on me instead.
Wed, Jun 24, 2009 at 8:07:06 AM | Revit 2010 Printing Problems
#13
RevitSVA
RevitSVA Avatar
You can also use drafting views - ex. place the image in a drafting view and then place it on the sheet!
This also works...
 I am not using hardware acceleration
Wed, Jun 24, 2009 at 9:23:01 AM | Revit 2010 Printing Problems
#14
RevitSVA
RevitSVA Avatar
What PDF writer did you use?
We use CutePDF and no problems...
Wed, Jun 24, 2009 at 9:31:32 AM | Revit 2010 Printing Problems
#15
CDYER36
5 Stars: 4 Votes
BEEN USING ADOBE ACROBAT 7.0
Revit Print Problems - UPDATE
Fri, Sep 2, 2016 at 1:44:13 PM
printing problems in Revit 2013, windows 10
Fri, Jul 3, 2020 at 3:08:01 AM
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
Printing image problems
Wed, Jun 15, 2011 at 12:01:40 AM
Revit 2010 printing random lines
Mon, Jan 4, 2010 at 10:51:09 AM
Page generation time: 1.8030
