Forums >> Revit Structure >> Technical Support >> Roof lines question
Thu, Apr 2, 2009 at 10:43:52 AM | Roof lines question
mreed
I am trying to use the roof command to put a fairly simple roof on a house.  For some reason the hip and valley lines are not going to the correct spot in some areas.  I have attached an image of what I am talking about.  Can someone tell me a way to get these to go to the correct location (i.e. corners)?
Thanks in advance.
Mike
Thu, Apr 2, 2009 at 12:46:29 PM | Roof lines question
Are you using overhangs and slope definitions to create this roof?  Make sure they are all the same and that the roof is defined form the same side of the wall (outside?)
Thu, Apr 2, 2009 at 1:12:38 PM | Roof lines question
4 Stars: 205 Votes
Yeah, you are doing something wrong....
Thu, Apr 2, 2009 at 1:20:58 PM | Typhoon
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Typhoon from 2009-04-02 13:12:38
sorry Typhoon, but i think your roof is incorrect also. that back gable should not continue and hit the ridge as you show it. it should  stay below the main house ridge from what i can see.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Apr 2, 2009 at 1:29:39 PM | Roof lines question
mreed
I am using overhangs and slope definitions.  I have deleted it and tried it several times, nut I am still getting this same result.  I can't figure out what is going on.
Thu, Apr 2, 2009 at 1:38:20 PM | Roof lines question
4 Stars: 205 Votes
Sorry for that Coreed, there it is.....
Edited on: Thu, Apr 2, 2009 at 1:39:14 PM
Thu, Apr 2, 2009 at 2:09:24 PM | Roof lines question
mreed
How did you do that?  I still cannot get mine to look that way.
Thu, Apr 2, 2009 at 2:13:49 PM | Roof lines question
4 Stars: 205 Votes
Just a Roof by footprint....
Thu, Apr 2, 2009 at 2:20:32 PM | Roof lines question
mreed
What version of revit are you using?  I did a roof by footprint and it will NOT look right.
Thu, Apr 2, 2009 at 2:23:31 PM | Roof lines question
4 Stars: 205 Votes
Revit Arch. 2009
Thu, Apr 2, 2009 at 2:47:21 PM | Roof lines question
#11
Let's talk about your mechanics.
I think all typhoon did was sketch his perimeter and set his slope designations,  Are you doing that or are you trying to force something?
Thu, Apr 2, 2009 at 2:56:47 PM | Roof lines question
#12
mreed
I have my perimeter walls. I go to the roof by footprint command. I give an overhang dimension of 1'-4". I then click on the "pick walls" command. I then set the "defines slope" command for the lines that define the slope and then change all of the angle to 6:12. I then click the finish roof. The attached image is what it spits out. The valley and hip lines should originate at the corners or intersections.
I am using Revit Structure 2009 if that makes a difference.
Edited on: Thu, Apr 2, 2009 at 3:03:29 PM
Thu, Apr 2, 2009 at 3:00:23 PM | Roof lines question
#13
4 Stars: 205 Votes
Can you put here your model??? so we can take a look, i think you are doing something wrong, I'm working in meters not in feets and fractional inches so i have dificult to understand your units....
Thu, Apr 2, 2009 at 3:18:42 PM | Roof lines question
#14
mreed
Try this.
Thu, Apr 2, 2009 at 3:40:52 PM | Roof lines question
#15
4 Stars: 205 Votes
yeah, you lie, you also change "Offset from roof base" in some lines like you can see in the images, if you pick in the "Align eaves" you can see what i post, so, it's natural what it's happen....
Sloped Roof Valley Lines question
Wed, Jul 23, 2008 at 11:49:30 AM
a roof question
Mon, Dec 31, 2007 at 1:15:04 AM
roof lines in floor plan view...i need them darker..how?
Tue, May 5, 2009 at 3:21:01 AM
a roof question...
Mon, Dec 31, 2007 at 12:03:39 PM
Extra Roof Lines in Section
Thu, Jan 28, 2016 at 12:45:54 PM
Page generation time: 0.6391
