Forums >> Revit Building >> Technical Support >> Levels, Disappeared.
Mon, Jun 20, 2005 at 6:51:20 AM | Levels, Disappeared.
remashiach
I originally created levels in my project which I cannot find on my elevations or sections any more. They still "exist" as I can attach walls etc to those levels. I want to delete them altogether butI can't. Any ideas?
Mon, Jun 20, 2005 at 6:26:58 PM | RE: Levels, Disappeared.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use a scope box. 1. Select the scope box tool in plan and draw a box to the full extents of your model. 2. Go to an elevation and drag the boxes top and bottom points so the box contains all model elements. 3. Draw a new level in elevation. 4. Right click on the newly created level and choose to select all instances. 5. Go to properties and set them to apply to the scope box. 6. They should now all be visible. You can delete the scope box if you no longer require it. HTH.
Tue, Jun 21, 2005 at 7:14:13 AM | RE: Levels, Disappeared.
ant
ant Avatar
I found levels and other things not displaying was due to OpenGL. Funny because Revit 6 worked fine with OpenGL on exactly the same computers.
Tue, Jun 21, 2005 at 12:43:33 PM | RE: Levels, Disappeared.
remashiach
Thanks, the scope box tool thing worked. This has probably saved me from lots of trouble. Cheers mate!
Thu, Apr 10, 2008 at 8:21:45 PM | Levels, Disappeared.
jarosa
jarosa Avatar
4 Stars: 5 Votes
How about that? A post from 2005 that did the trick again. thanks Mr. Spot.
John
Fri, Oct 31, 2008 at 10:13:03 AM | Levels, Disappeared.
WALLYBALLS
worked to perfection! great job
Thu, Jan 22, 2009 at 8:50:39 PM | Levels, Disappeared.
NancyHKA
this worked like a charm on our mysterious missing levels.  thanks so much!
Tue, Jan 12, 2010 at 8:39:24 PM | Levels, Disappeared.
Cece01
Oh my gosh. Mr. Spot. You are AMAZING. This has saved me so much trouble, THANK YOU.
Tue, Apr 20, 2010 at 1:52:49 PM | Levels, Disappeared.
edawson
I have no idea how it works, but it did the trick!
Thu, Nov 4, 2010 at 11:59:42 AM | Levels, Disappeared.
jmarkle
All,
I'm having the same problem described in the initial post on this thread. Only, this solution, which seems to work wonders for everyone else is failing me, and I'm completely stumped.
I have one level in particular that isn't showing up in any of my elevations or sections. There's no question of the level not existing because I have a floor plan. I've zoomed out to the far regions of my model, and I've tried setting all of the level extents to a scope box. Still no level. Is there any additional insight?
Thu, Nov 4, 2010 at 12:01:01 PM | Levels, Disappeared.
#11
jmarkle
Also - I've unhidden any hidden levels and set their extents to the scope box. I have no clue where this level is.
Thanks in advance.
Thu, Nov 4, 2010 at 12:01:19 PM | Levels, Disappeared.
#12
Follow Mr. Spot's instructions !
Thu, Nov 4, 2010 at 12:05:07 PM | Levels, Disappeared.
#13
jmarkle
Thanks in advance.
Thu, Nov 4, 2010 at 12:06:19 PM | Levels, Disappeared.
#14
jmarkle
I did follow Mr. Spot's instructions. 3 times. Still no level.
Mon, Nov 29, 2010 at 8:02:43 AM | Levels, Disappeared.
#15
Emerson1899
I was in the same boat -- turned out that the two levels which wouldn't show up in any views were on a workset that by default, wasn't visible.  The Scope Box trick didn't work for me, because of this.  Could be another reason for people.
First Floor Level Marker Disappeared
Tue, May 19, 2015 at 10:56:23 AM
My window disappeared!
Mon, Oct 29, 2007 at 1:37:03 PM
reply button seems to have disappeared
Fri, Dec 10, 2010 at 5:08:45 PM
Structural grid lines disappeared
Sat, Feb 18, 2017 at 1:51:29 PM
door swings disappeared
Thu, May 10, 2012 at 7:11:37 AM
Page generation time: 0.0995
