Forums >> Community >> Newbies >> neebie
Thu, Jan 15, 2009 at 2:02:18 PM | neebie
ksobon
3 Stars: 4 Votes
hi iam a total rookie in this matter so the question might seem out of place but how to make one of my walls in revit tilted?
Thu, Jan 15, 2009 at 2:05:34 PM | neebie
4 Stars: 205 Votes
Well, in a elevation view pick in the wall and "EDIT" then you enter in sketch mode, then is just create the shape you want...
Thu, Jan 15, 2009 at 2:38:06 PM | neebie
ksobon
3 Stars: 4 Votes
well it seems easy but for some reason revit wont let me move any lines in the horizontal workplane i mean if i could move the top line then i would then just grab the two sides and snap them to the top and that would gimme tilted wall but again revit wont let me rotate or move any lines in the horizontal workplane...any idea?
Thu, Jan 15, 2009 at 2:42:56 PM | neebie
ksobon
3 Stars: 4 Votes
yeah i cant draw in plan view cause of hte workplane...how do i change it?? so it allows me to draw lines in the plan?
Thu, Jan 15, 2009 at 2:48:52 PM | neebie
4 Stars: 205 Votes
Hi again, see this: http://screencast.com/t/rwyzcYgA7
Thu, Jan 15, 2009 at 3:00:38 PM | neebie
ksobon
3 Stars: 4 Votes
well i know how to do that you misunderstood me...i meant TILT the wall like on the picture....http://i82.photobucket.com/albums/j277/monitordeals/76_1.jpg its on the angle with respect to the vertical plane....any idea?
Thu, Jan 15, 2009 at 3:20:00 PM | neebie
4 Stars: 205 Votes
OK, see the video: http://screencast.com/t/oii5MuEvnxJ
Thu, Jan 15, 2009 at 3:38:11 PM | neebie
ksobon
3 Stars: 4 Votes
that is great!!! thanks that's all that i needed and much more thanks for not just showing me how to do it but explaining how to control it and modify if i need to ....thanks i believe that the same set of rules would follow if i wanted wall that curves around the corner and is tilted at the same time...? just a suggestion
Fri, Jan 16, 2009 at 4:52:25 AM | neebie
4 Stars: 205 Votes
"thanks i believe that the same set of rules would follow if i wanted wall that curves around the corner and is tilted at the same time...? " - Well in this case you must use not the Extrusion but the "Solid Sweep" with a "Path"...
Fri, Jan 16, 2009 at 10:01:40 AM | neebie
ksobon
3 Stars: 4 Votes
well technically i still draw that very same side elevation of the wall that i used to extrude but i also give it a path to follow by placing a curved line right? that makes sense...thx
Fri, Jan 16, 2009 at 11:25:42 AM | neebie
#11
4 Stars: 205 Votes
I'm not sure if i understand your question but if you have a Curved wall-Tilted like you said you MUST use the "Solid Sweep" were you must put the "Path" then the "Profile"....
Fri, Jan 16, 2009 at 12:15:48 PM | neebie
#12
ksobon
3 Stars: 4 Votes
any idea how to get these windows to follow the profile of the wall??? i mean i dont want them to stick out like that...
Sat, Jan 17, 2009 at 10:20:07 AM | neebie
#13
4 Stars: 205 Votes
You can create the window in a "Generic Model Face Based" family, then when you put the window in the wall it attached to the inclinated face of the wall....
Mon, Jan 19, 2009 at 4:47:26 AM | neebie
#14
audyr1
4 Stars: 1 Votes
hello...
 wnever i render a night scene d car lights dnt show up or glow... cn u tell me wots d problm????
Mon, Jan 19, 2009 at 8:35:08 AM | neebie
#15
ksobon
3 Stars: 4 Votes
thank you typhoon you are the most helpful person i have ever talked to if you ever need eny help with CAD, 3ds max, photoshop or illustrator just holla at me....ksobon@iit.edu
Page generation time: 0.5353
