Forums >> Revit Building >> Technical Support >> make arc wall under stair
Fri, Dec 5, 2008 at 3:06:08 AM | make arc wall under stair
trandung
Wall can not attach with stair . How What to do ?
Fri, Dec 5, 2008 at 4:45:17 AM | make arc wall under stair
4 Stars: 205 Votes
Hi, you only can "Attach" wall to wall or to Slab and Roofs, but the image it's seems good, what's the problem?
Fri, Dec 5, 2008 at 6:57:20 AM | make arc wall under stair
trandung
I want draw a wall under arc stair .
Fri, Dec 5, 2008 at 7:07:32 AM | make arc wall under stair
4 Stars: 205 Votes
I don't get it, by Your images you just create a wall under the stairs using the "Swept Blend", are you talking about the category of the wall? when you create a in-place you can choose the category for your elements but if you choose at the begining a "Generic Model" you can change that if you edit the "Object-swept blend" and in Settings-Family category and parameters and change to "Wall".... if this is what do you want...
Fri, Dec 5, 2008 at 7:22:33 AM | make arc wall under stair
trandung
number 1 : sample wall
number 2 : My wall
I like my wall same number 1.
Fri, Dec 5, 2008 at 7:25:51 AM | make arc wall under stair
trandung
I see this web. I like learning some video sample . But I can nót see . Why do you know ? Thanks
Edited on: Fri, Dec 5, 2008 at 7:36:32 AM
Fri, Dec 5, 2008 at 7:28:45 AM | make arc wall under stair
4 Stars: 205 Votes
OK, so create a "VOID SWEPT BLEND" to remove that portion of wall....
Fri, Dec 5, 2008 at 7:39:29 AM | make arc wall under stair
trandung
Can you train for me ? Thanks
Fri, Dec 5, 2008 at 9:08:04 AM | make arc wall under stair
4 Stars: 205 Votes
I don't have here Revit and JING to create a video for you, can you wait??? OR "Rkitect" can you made a video for him??
Fri, Dec 5, 2008 at 9:37:18 AM | make arc wall under stair
rkitect
rkitect Avatar
4 Stars: 29 Votes
The way I understand this is that you want the wall to actually attach to the stair.  Does this mean you want the wall to adjust itself if the stair moves up or down?
Fri, Dec 5, 2008 at 9:39:13 AM | make arc wall under stair
rkitect
rkitect Avatar
4 Stars: 29 Votes
Ah.. Wait.. I think I see what you are saying.  Your Void Swept Blend is not cutting your wall.  Is this correct?
Fri, Dec 5, 2008 at 9:47:09 AM | make arc wall under stair
trandung
Oh yes. My friend send for me one file . It has a wall under arc stair. I try draw same but can not do that.? Thanks youEdited on: Fri, Dec 5, 2008 at 9:49:12 AM
I saw this web , but can not see video ?
http://autodesk-revit.blogspot.com/2008/03/swept-blend-tool-in-revit-architecture.html
Edited on: Fri, Dec 5, 2008 at 10:46:10 AM
Fri, Dec 5, 2008 at 10:25:37 AM | make arc wall under stair
#13
4 Stars: 205 Votes
Yeah, the video is there, pick here: http://www.cadscope.co.uk/movies/swept_blend/swept_blend.html
Fri, Dec 5, 2008 at 10:50:34 AM | make arc wall under stair
#14
trandung
This web can not see ??? this is mydesktop.
You try to help for me. Thanks so much . Now I must go to bed ! See you again
Edited on: Fri, Dec 5, 2008 at 10:54:49 AM
Fri, Dec 5, 2008 at 11:03:14 AM | make arc wall under stair
#15
rkitect
rkitect Avatar
4 Stars: 29 Votes
My guess is that you can not see the video because you do not have the latest version of flash installed.  This means you probably won't be able to see this video either, but you can give it a shot:
http://gibsonhh.info/revit/video/slopedCurveWall_2009.swf
HTH,
Edited on: Fri, Dec 5, 2008 at 12:10:21 PM
how to make an arc reveal in a wall in revit?
Fri, Oct 22, 2010 at 7:17:06 AM
Problem railing arc stair
Thu, Dec 4, 2008 at 5:40:47 AM
how can I make an arc setback in a revit wall, not openings.
Mon, Oct 25, 2010 at 1:26:48 AM
fillet arc on stairs
Fri, Oct 28, 2011 at 12:39:35 PM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Page generation time: 0.9778
