Forums >> Revit Building >> Technical Support >> Wall Join help - options not working
Fri, Sep 26, 2008 at 12:55:34 PM | Wall Join help - options not working
jmqrsq
5 Stars: 3 Votes
Take a look at my screenshot. I cannot get this to join correctly and wrap the end of the wall. Any help would be appreciated.
Wed, Apr 22, 2009 at 3:24:14 PM | Wall Join help - options not working
JDAGEN
I'm having the same problem. Any help would be appreciated. We suspected that it have with the wall being drawn with different location lines. For intance one wall drawn by the core and another drawn by an interior face.
Wed, Apr 22, 2009 at 3:37:41 PM | Wall Join help - options not working
4 Stars: 205 Votes
Did you try with the "Edit wall join"??? trim and/or extend the two walls???
Thu, Apr 23, 2009 at 7:12:53 AM | Wall Join help - options not working
JDAGEN
The wall join tool did not fix the problem.
Thu, Apr 23, 2009 at 7:20:03 AM | Wall Join help - options not working
jmqrsq
5 Stars: 3 Votes
interesting idea about the drawn by theory. I have yet to find a suitable fix for this. If I do I will let you all know and please do the same.
Thu, Apr 23, 2009 at 7:43:24 AM | Wall Join help - options not working
The short wall joins issue has been addressed before but I can't remember the answer.  There is a video tutorial that explains how to get the joins to work that was posted here or on AUGI.  Perhaps someone can find the link and post it again.
Thu, Apr 23, 2009 at 8:13:58 AM | Wall Join help - options not working
4 Stars: 205 Votes
Yeah WWhub, NOW I remember what are you talking, i don't have here "jing" and Revit to make a video but it's when you pick in the wall appears the "Blue Dots" with the temporary dimensons and if you pick Or "drag" those "blue dots" you can fix the problem of those walls...
Thu, Apr 23, 2009 at 8:37:23 AM | Wall Join help - options not working
OK - attached sketch shows what I remember...  REVIT seems to want to clean up the walls in a progession so work in one direction or the other.
Thu, Apr 23, 2009 at 10:05:17 AM | Wall Join help - options not working
JDAGEN
Thanks for the suggestion. Unfortunately, we followed your steps of splitting the wall but it only cleaned up one side. This problem appears to happen when a wall offset is less than the thickness of the wall. Draw order seems to play a role. We have tried to drag the blue dots to clean things up wich has worked in some instance but not others. The link mentioned earlier would be a huge help. This is our firm's first pilot Revit project. Little 'quirks' like this can make the partners and decision makers skeptical of Revit, when this prblem wouln't occur in Autocad. I am really thnkful for this forum and the help everyone supplies.
Thu, Apr 23, 2009 at 10:16:22 AM | Wall Join help - options not working
Look at all the sketches ... it cleaned up one side.... split the next wall and the other side cleans up - then rejoin that wall!
Thu, Apr 23, 2009 at 1:27:08 PM | Wall Join help - options not working
4 Stars: 205 Votes
Hi, this is the other solution i'm was talking, see the video: http://www.megaupload.com/?d=XIIE4P9E
But it's faster the way of WWhub....
Edited on: Sat, Apr 25, 2009 at 11:22:40 AM
Thu, May 7, 2009 at 3:10:43 PM | Wall Join help - options not working
JDAGEN
Thank you so much for your help Typhoon. Excuse my stupidity. Following your last step worked. However, having moved on, I have encountered the same problem, but the same work-around does not work. Do you know the source of the problem. Does Revit 'prefer' all walls be drawn in the same direction: ie. clockwise or counter-clockwise, with the same refrence, ie interior core face. I am trying to find the source of the prblem so I don't propogate the same 'bugs'.
Thank you!
Fri, May 8, 2009 at 2:25:04 PM | Wall Join help - options not working
#13
4 Stars: 205 Votes
I don't see any difference if i create those walls in clockwise or counter-clockwise, with the same refrence, ie interior core face, no matter, it works fine, i did several testings and no problem at all.... it's very tricky but it works, try the WWhub way, it's faster...
Fri, May 8, 2009 at 3:26:14 PM | Wall Join help - options not working
#14
JDAGEN
I will look at the method you mention. I have several of these conditions on my plan. It seemed in that being consistant really did help eliminat many of the problems, however now I found if I cut wall openings in theese wall the prblem comes back, I fix one bump out then 2 others in the series develop the problem again. I correct it, change the opening height, the proble re-appears. I really think Revit is a great tool, but this seems like a major flaw.
Fri, May 8, 2009 at 3:38:20 PM | Wall Join help - options not working
#15
JDAGEN
Is the WWHB method somewhere else I am having problems downloading it - Megadownload proxy issues.
Wall Join Options Disappear [ 1 2 ]
Tue, Apr 23, 2013 at 3:45:22 PM
26
Wall join options
Wed, Mar 23, 2011 at 7:46:49 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:48 AM
11
90degree wall join
Sun, Aug 20, 2006 at 9:08:54 PM
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
Tue, Jul 22, 2008 at 9:38:24 AM
Page generation time: 3.0330
