Forums >> Revit Building >> Technical Support >> mysterious hole in wall
Tue, Feb 5, 2008 at 1:08:19 PM | mysterious hole in wall
archshanna
there is a void in my wall that i did not draw and i can't get rid of it...  there's nothing there that i can tell that is cutting it.  no demo or existing object in the way.  nothing above or below that should be cutting the wall this way.  you can see this hole in elevation and 3d as well.  if i delete the wall and redraw or even just draw a wall next to it, the hole is still there....  help!
Tue, Feb 5, 2008 at 1:20:22 PM | mysterious hole in wall
stevelj
It looks like you have something turned off or in a different Phase. Also, try clikcing on the light bulb at the bottom of the screen.
Tue, Feb 5, 2008 at 1:31:18 PM | mysterious hole in wall
archshanna
i've tried turning on all phases and turning on everything using visibility graphics and the light bulb...nothing's there....
Tue, Feb 5, 2008 at 1:57:58 PM | mysterious hole in wall
stevelj
Can you post your file if it's not to big?
Tue, Feb 5, 2008 at 2:10:56 PM | mysterious hole in wall
stevelj
Are the wall ends set to allow joins?
Tue, Feb 5, 2008 at 2:13:57 PM | mysterious hole in wall
archshanna
file is too big.  idk why it keeps posting my same reply over and over again.  how do u check that wall join thing?
Tue, Feb 5, 2008 at 2:32:00 PM | mysterious hole in wall
archshanna
ok so messing with allowing/disallowing wall joins doesn't get rid of the stupid hole...
Tue, Feb 5, 2008 at 2:33:22 PM | mysterious hole in wall
stevelj
Try detaching walls from floor and roof s if you got them.
Tue, Feb 5, 2008 at 2:40:04 PM | mysterious hole in wall
archshanna
Tue, Feb 5, 2008 at 2:45:26 PM | mysterious hole in wall
archshanna
Tue, Feb 5, 2008 at 2:46:51 PM | mysterious hole in wall
archshanna
it's detached from everything
Tue, Feb 5, 2008 at 2:48:00 PM | mysterious hole in wall
archshanna
attaching the wall to the ceiling/roof/floor doesn't fix it either...
Tue, Feb 5, 2008 at 2:50:27 PM | mysterious hole in wall
#13
stevelj
Are you using design options?
Tue, Feb 5, 2008 at 3:00:56 PM | mysterious hole in wall
#14
stevelj
Try setting your Phase to Show All
Tue, Feb 5, 2008 at 3:24:07 PM | mysterious hole in wall
#15
archshanna
Applying Materials To Cover A Hole
Mon, Mar 10, 2008 at 8:26:30 PM
Curtain wall in wall hole
Tue, Sep 8, 2009 at 7:03:33 PM
cutting a hole in a massed floor/roof
Mon, May 11, 2009 at 7:07:00 AM
Mysterious Notch in Wall
Tue, Dec 14, 2010 at 4:29:42 PM
How to infill a topo hole from plit surface
Fri, Jun 15, 2012 at 9:54:54 AM
Page generation time: 1.1248
