Objects
Page 1 of 6 | 1 | 2 | 3 | 4 | 5 Next >>
122400
122400
hope you enjoy it
4 Stars from 12 Votes
Product Version: Unknown
13138 Downloads
183500 94 cm height
183500 94 cm height
4 Stars from 2 Votes
7056 Downloads
4589
4589
1 Stars from 1 Votes
795 Downloads
7 inch fluted
7 inch fluted
7 inch fluted
3 Stars from 1 Votes
Product Version: Revit Building 5.1
3727 Downloads
7' 2" Pilaster
7' 2" Pilaster
Fypon Pilaster
6721 Downloads
9 Inch Pilaster Fluted
5953 Downloads
9' Column with vine coil
9 foot column. material can be edited.. rate guys! and girls!
3.5 Stars from 6 Votes
19019 Downloads
Arch Column 2017
Arch Column 2017
Mostly Parametric and Materials
Base and Support arm on /off
Made for a project Hope it works for you
just trying to give back !
Revit 2017
3064 Downloads
Architectural Column
5 Tier, each with height, width, and material parameters
1st effort, so be kind
2901 Downloads
architectural column
a column i designed that has dimensional timber on top and a tall plinth made of concrete.  metal brackets connect these two elements.  all materials can be modified.
5 Stars from 2 Votes
2275 Downloads
5266 Downloads
Architectural Columns
Architectural Columns 300mm Diameter
4 Stars from 1 Votes
Product Version: Revit Structure 2018
5259 Downloads
Architectural Rectangular Column
Rectangular architectural hollow column. Type Parameters: Depth and Width. Plus 6 instance parameters.
5 Stars from 3 Votes
19666 Downloads
Bamboo column
4 poles straight
674 Downloads
Bamboo column
Bamboo column
Mushroom column with bamboo
4767 Downloads
Barnard Cloister Column with Base - Max Aguilar
Its a rough draft of the base, the capital of the column is still needed. This is because each column has a different capital design.
624 Downloads
Best Column
Best Column
Flawless
2.5 Stars from 7 Votes
9650 Downloads
Boxed column
Boxed column
boxed column wraped around 4X4 post
3 Stars from 3 Votes
17108 Downloads
Bracket Scroll
Bracket Scroll
Scaleable Bracket Scroll
3886 Downloads
Built up Square column
A basic built-up square column with wood base and cap.
4.5 Stars from 3 Votes
27285 Downloads
Built up Square column w/ cap
A basic built-up square column with wood base and cap for use as a newel post on a portico.
3.5 Stars from 3 Votes
10681 Downloads
Cabinet
168 Downloads
Circular_Mushroom_Column
This is a 3D Family of Circular Mushroom Column. All constraints are editable.
Product Version: Revit Architecture 2019
725 Downloads
329 Downloads
641 Downloads
classic column
classic column
parametric column made by revit 2021
2404 Downloads
Classical column
Classical column
Parametric: you can change height (adjust to levels) and materials
2 Stars from 1 Votes
6851 Downloads
Classical Column w/ Entasis - Tuscan Order (Parametric)
Parametric Tuscan order classical column with entasis. Based on the proportions of the classical orders. Only requires the lower shaft diameter to be sized accurately.
4156 Downloads
Clux Cloisters Column - Max Aguilar
SImple Clux Cloister Column for Fordham Medieval Studies Projects.
3 Stars from 2 Votes
1523 Downloads
Colonial Post Sweep
Colonial Post Sweep
Colonial Post Sweep Para Material
3268 Downloads
Page generation time: 0.3008
