Objects
Page 1 of 25 | 1 | 2 | 3 | 4 | 5 Next >>
025
025
WWW.REVITOBJ.COM
WWW.REVITOBJECT.IR
1202 Downloads
1 Drawer Base Cabinet
Microwave base
6174 Downloads
1 Rectangle Mirror
Product Version: Revit Structure 2009
3646 Downloads
2 Drawer Base Cabinet
6657 Downloads
2-Door Cabinet (editable)
A generic wood cabinet with the handles toward the bottom that you can specify to meet you need. You can move the handles and change the material if needed in the family view.
4 Stars from 12 Votes
Product Version: Unknown
29584 Downloads
21 inch ADA Vanity Bracket
Vanity bracket that holds skirt
341 Downloads
3 Drawer Base Cabinet
3 equal drawer base cabinet with height parameter based on revit 4 drawer model.
4 Stars from 4 Votes
15152 Downloads
3 Drawer Vanity Cabinet
3.5 Stars from 3 Votes
10052 Downloads
36'' Lazy Susan Base Corner Cabinet with ONE rotating shelf
1 connected swing-out door with ONE rotating circular shelf
Image is from http://trendkitchencabinets.com/wp-content/uploads/2012/11/Menards-Kitchen-Cabinets-Unfinished-1.jpg
4 Stars from 5 Votes
20493 Downloads
36'' Lazy Susan Corner Base cabinet with TWO rotating shelves
Lazy Susan with 1 connected swing out door and TWO rotating shelves
5 Stars from 4 Votes
16399 Downloads
4 door wall glass cabinet recessed
A parametric wall cabinet/ display case with 4 doors. You can change the width, depth, height and materials. The doors will remain equal to each other in size.
4.5 Stars from 2 Votes
4668 Downloads
45 and 90 degree countertop
Adjust length of leg's 1, 2 and 3, counter depth and thickness.
Product Version: Revit Building 9.1
6694 Downloads
48" Cast Stone Range Hood
9595 Downloads
50mm Caster Wheel
50mm Caster Wheel
Caster Whell (50mm) for furniture - Revit 2021
4 Stars from 2 Votes
2649 Downloads
6ft by 3ft Mirror w/ wood trim
wall based 6ft wide by 3ft high mirror designed for public bathrooms. Default 4ft above floor.
3 Stars from 5 Votes
38649 Downloads
75mm Caster
75mm Caster
75mm Caster suitable for cabinets etc.
8032 Downloads
ADA Sink Skirt
ADA Sink Skirt
This is based on a Steelcase sink skirt.  It is adjustable for width only as a type.  You will have to duplicate if you have more than one size in your project.
6835 Downloads
adjustable display cabinet
1 Stars from 1 Votes
9769 Downloads
Adjustable Double Vanity
Adjustable Double vanity bench top and tops. Not fully modeled. Better be used only in plan and elevation views.
4615 Downloads
Angled Corner Cupboard
Angled corner cupboard. (Part of the default revit domestic kitchen set)
3719 Downloads
Angled_Corner_Cupboard_4536.rfa
1010 Downloads
Appliance Garage
Appliance Garage
made at NOHS. appliance garage, kitchen, toaster, coffee machine, cabinet
8027 Downloads
Applience Garage
Applience Garage
applience garage made at NOHS by Jack Perry
1436 Downloads
Armário Cozinha Paramétrico - Modelo 01
Armário Cozinha, podendo:
-Dimensões, Altura, Largura, Profundidade, Espessura Moldura e Altura do Puxador
-Materiais: Moldura, Porta, Gaveta, Puxador e Tampo Superior;
-Visibilidade do Tampo superior: Caso oculte o tampo, adicionar a Altura do armário a altura que o tampo ocupava.
Visibilidade da Porta: Caso a oculte para deixar visível as prateleiras, oculte também o puxador. A altura do armário, some a altura do puxador.
1720 Downloads
Armário Cozinha Paramétrico - Modelo 03
-Dimensões, Altura, Largura, Profundidade e Espessura da Moldura;
-Materiais: Moldura, Porta, Puxador e Tampo Superior;
-Visibilidade: Tampo superior. Caso oculte o tampo, adicionar a Altura do armário a altura que o tampo ocupava.
1114 Downloads
Armário Cozinha Paramétrico - Modelo 05
-Dimensões, Altura, Largura, Profundidade e Espessura da Moldura e Altura do Puxador;
1645 Downloads
ASIA MODERN SHELVING UNIT
72HX14WX36L
2449 Downloads
AWI 100 - Base Cabinet - Open
Base Cabinet - Open
*** IMPORTANT: The shared parameters file must be pointed to inside Revit.  All casework families built by myself can point to the same shared parameter file. ***
  • Do not adjust parameters under "Other" category.
  • Please save the shared parameters file in the same directory as the cabinet family.
Any comments would be appreciated.
4361 Downloads
AWI 101 - Base Cabinet - 1 Door
7457 Downloads
AWI 102 - Base Cabinet - 2 Door
4 Stars from 1 Votes
12814 Downloads
Page generation time: 0.0605
