11 7/8 inch I-Joist Arrows |
Product Version: Unknown
2970 Downloads
14 inch I-Joist Arrows |
No rating |
1603 Downloads
This is a 2-pick line-based break line symbol. After you click once to start the break line, an invisible line arrow will appear to indicate which side of the line the mask will be on. By default it masks on the same side/direction as the exterior side of walls, i.e. outer side of a clockwise loop.
It also has a view scale parameter, which you can enter before you start drawing the break line. Simply enter the view scale for each break line you draw, and all your break line jogs in your entire project will match size and shape exactly.
Note: the arrow is only visible while drawing the break line, or when you hover the mouse over it or pick it. |
15374 Downloads
No rating |
2152 Downloads
This component is used to put 2d lines in a model for closet rod and Hangers It is parametric in length and easy to pull the ends to the length of the closet. |
20382 Downloads
2 D Elevtion Parametric Tree : Height Parameter adjusts with width (Scalable) |
6973 Downloads
2X10 floor joist arrows |
No rating |
2230 Downloads
2x12 Floor Joist Arrows |
No rating |
2081 Downloads
2X8 floor joist arrows |
No rating |
1682 Downloads
Need to point to something in your 3D enviroment, Come with 3 colours each - easy to add other colours. |
No rating |
1175 Downloads
No rating |
773 Downloads
No rating |
1133 Downloads
1348 Downloads
No rating |
621 Downloads
No rating |
713 Downloads
No rating |
2469 Downloads
9 1/2 inch I-Joist arrows |
No rating |
1325 Downloads
This is the modified version of original room tag. |
11358 Downloads
A2 LANDSCAPE BUTTOM PANELLED TITLE BLOCK |
7482 Downloads
A3 parametric HEBREW landscape |
3872 Downloads
A3 parametric HEBREW portrait |
2565 Downloads
An A3 title block for professional working drawing |
20755 Downloads
Modeled in Revit 2024 |
No rating |
744 Downloads
This is an A4 titleblock. For the metric system [obviously] I decided to upload this as I found it difficult to find a l decent A4 landscape title block. |
8836 Downloads
Above Ceiling Device As Shown Symbol
No rating |
946 Downloads
addendum symbol |
1650 Downloads
Align symbol made in Revit 2012 using instance parameters to adjust the depth and width of the symbol. Arrowheads are 1/8" 30degree filled arrowheads. |
No rating |
1447 Downloads
Plan or detail break line symbols. |
No rating |
457 Downloads
Generic Annotation - FOR REFERENCE ONLY stamp |
No rating |
Product Version: Revit Building 9.1
1272 Downloads
Dimension family create with Revit 2022 |
386 Downloads
