Objects
Page 1 of 64 | 1 | 2 | 3 | 4 | 5 Next >>
*Updated* Box of doughnuts
Here's an updated version of the box of doughnuts with the right size and measurments for use!
I'll be design more components!
food , doughnut , box
5 Stars from 2 Votes
Product Version: Revit Structure 2017
11060 Downloads
Full Version
 πŸ”— Gumroad – Full LOD 400 Version:
.javascript:mctmp(0);
 πŸ”— Etsy – Parametric Door Family (LOD 400):
Product Version: Revit MEP 2020
17 Downloads
Full Version
www.arsalanfard.com
17 Downloads
‍Free Sample — Parametric Frameless Door (Revit Family)
This is a free sample version of my parametric frameless door family for Revit.
The sample includes basic parameters for testing and preview purposes.
 For the full LOD 400 version, advanced features, and more professional Revit door families, please visit the links below:
 If you found this sample useful, feel free to explore the complete collection.
Thank you!
www.arsalanfard.com
18 Downloads
026
026
WWW.REVITOBJ.COM
WWW.REVITOBJECT.IR
2 Stars from 4 Votes
3012 Downloads
04 23 00 - Glass Block Unit
7 3/4" x 7 3/4" x 3 1/8" - Parametric
3.5 Stars from 16 Votes
Product Version: Unknown
27463 Downloads
1/4-12_Cricket-complex trig
Roof cricket that is easy to use and reflect actual construction size for 1/2:12 sloped insulation. made with complex trig formulas. easily gives you slopes in all directions. Roof hosted. INSTRUCTIONS: place on roof surface. Adjust Li & Hi (i.e. lenght and depth of cricket) in decimal FT and align to the walls. only works on right angles.
1112 Downloads
13 Gallon Trash/Recycling Receptacle
Tall kitchen trash/recycling receptacle
1 Stars from 1 Votes
15747 Downloads
18"x18"x24" Side Table
Simple Arts and Crafts Side Table
2848 Downloads
20'x36' Pool (3'-5' depth)
4 Stars from 7 Votes
16219 Downloads
3-Sided Peninsula Fireplace - Freestanding
Ortal Space Creator 3-Sided fireplace. 2 long glass sides, 1 narrow. Included options for 3 sizes, fully parametric.
3328 Downloads
30ft glass elevator
30ft glass elevator
4.5 Stars from 5 Votes
20868 Downloads
3d Gridline and 3d Dimension
3d Gridline and 3d Dimension is used for clash detection model for enscape, lumion, twinmotion and many other clash detection software.
582 Downloads
3D spline railing
3D spline railing
Here's an adaptive component that generates a 2" diameter rail through 8 movable points set by the user.
You have to hit TAB to select the adaptive points in order to get the XYZ grips.
2270 Downloads
3D sports court
3d basketball/volleyball court drawn to high school dmensions and specifications.
3.5 Stars from 3 Votes
12581 Downloads
3d tray
3d tray
Create By Mohamed Mostafa
at Revit 2015
My Channel Youtube
https://www.youtube.com/c/MohamedMostafaAlsharif
My Page in FaceBook
https://www.facebook.com/3dquality
2001 Downloads
3Form Panel & Suspension System (Panel)
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE PANEL. THE SUSPENSION SYSTEM IS A SEPARATE DOWNLOAD.
4.5 Stars from 3 Votes
7795 Downloads
3Form Panel & Suspension System (Suspend Hardware)
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE SUSPENSION SYSTEM. THE PANEL IS LOCATED IN A SEPARATE DOWNLOAD.
4031 Downloads
4 Panel Bifold Door Glass
4 Panel Bifold Door Glass Modified from 4_Panel_Bifold_Door_18619
7833 Downloads
4 Point Tensile Canopy
Adaptive Revit Family with Central offset parameter. material parameter.
199 Downloads
6' Step Ladder
6' Step Ladder
3 Stars from 2 Votes
6426 Downloads
6' Step Ladder - converging
Top width: 14"
Bottom width: 22"
2071 Downloads
8" Hexagon Model Pattern
8" Hexagon .pat file can be used in revit and other supported software.
How to use in revit
1.Copy the text. open note pad. Paste it and save with .pat(dot pat) extension
2. Open material tab then surface pattern then model pattern-- New--load the pat.
4.5 Stars from 8 Votes
5559 Downloads
A BASIC CASKET
A BASIC CASKET
NEEDED A CASKET FOR A PROJECT I WAS DOING.  I DIDN'T SEE ANY ON HERE SO I MADE A VERY BASIC ONE.
1020 Downloads
a bicycle stand
a bicycle stand
a bicycle stand, stojak na rowery, na staΕ‚e zakotwiczenie do gruntu
12397 Downloads
A real spiral stair to code
This spiral stair is made up of many different components and was not made with the stair command at all.
Product Version: Revit Structure 2009
11036 Downloads
A Wood Crate
A Wood Crate
A wood crate with metal frame that is full parametric  in height, length, depth, and materials can be change for framing and the crate surface, so it can be a wood crate or any type of crate as need. Fruits are not included. Enjoy!
20521 Downloads
A325 Heavy Hex Nut
A325 Heavy Hex Nut
ASTM A325 Portland Bolt Heavy Hex Nut: 1/2", 5/8", 3/4", 7/8", 1", 1-1/8", 1-1/4", 1-3/8", 1-1/2"
Product Version: Revit Architecture 2019
458 Downloads
Acoustic Wall-Based Panel
Generic, strechable-acoustic wall-based panel. Will host to a wall. Enjoy!
6871 Downloads
ADA BRAILLE SIGNS FILE 1
All signs are wall based and should be set at 5' A.F.F. at teh bottom of the bottom of the lowest text.
5638 Downloads
Page generation time: 0.1291
