Objects
Page 1 of 38 | 1 | 2 | 3 | 4 | 5 Next >>
"THE SANDIE POOL"
An advanced pool that was created in Revits Architecture 09'
4.5 Stars from 3 Votes
5596 Downloads
3.5 Stars from 3 Votes
Product Version: Unknown
1527 Downloads
00Quadripod00
I make this object for break waves, cause we have more than 18.000 islands...Surya Consultant, Tual, Maluku Tenggara, Indonesia..
5 Stars from 5 Votes
1511 Downloads
00Quadripod00
00Quadripod00
This object is useful for break waves..Work Plane Based...Surya Consultant, Tual
2 Stars from 3 Votes
4660 Downloads
1-1932 RAT ROD
1-1932 RAT ROD
3 Stars from 2 Votes
6245 Downloads
1-1949 COUPE
1-1949 COUPE
8638 Downloads
1-1959 ELDORADO
1-1959 ELDORADO
1 Stars from 2 Votes
5949 Downloads
1-1961 IMPALA
1-1961 IMPALA
4695 Downloads
1-1963 STINGRAY
1-1963 STINGRAY
8491 Downloads
1-1964 CONTINENTAL
1-1964 CONTINENTAL
4 Stars from 1 Votes
4610 Downloads
1-1964 DB5
1-1964 DB5
6018 Downloads
1-1965 GTO
1-1965 GTO
3493 Downloads
1-1966 AMAZON
1-1966 AMAZON
3610 Downloads
1-1967 GT 500 (ELEANOR)
4.5 Stars from 6 Votes
20137 Downloads
1-1968 CHARGER
1-1968 CHARGER
5483 Downloads
1-1968 KARMANN GHIA
1-1968 KARMANN GHIA
5 Stars from 2 Votes
4141 Downloads
1-1969 Z28 CAMARO
1-1969 Z28 CAMARO
8271 Downloads
1-1970 CHALLENGER
1-1970 CHALLENGER
4620 Downloads
1-1971 GTO (THE GUDGE)
3829 Downloads
1-1972 CHEVELLE
1-1972 CHEVELLE
4906 Downloads
1-1977 TRANS AM (THE BANDIT)
i dont know why the rendition came out crappy but oh well
1 Stars from 1 Votes
5696 Downloads
1-1983 IROC
1-1983 IROC
5361 Downloads
1-1987 GRAND NATIONAL
4.5 Stars from 2 Votes
3270 Downloads
1-1995 V-TWIN BOBBER
17396 Downloads
1.5m Euro Barrier
1.5m Euro Barrier
Generic 1.5m long 800mm high 300mm wide road traffic barrier
1075 Downloads
10' Chainlink Fence
10' Chainlink Fence
This was done with the railing tool. Super clean and easy to use. Copy from the RVT file to your Project. If you get ambitious, add some piles and a no tresspassing sign.
NOTE:
You may need to adjust the material to ensure it looks correct. The chainlink is a model line drafting hatch.
Also, if you change the height, you will need to adjust the 'Chainlink Fence Panel' Profile to suit.
Good Luck - RFB
4.5 Stars from 5 Votes
15614 Downloads
12 Big Air Trampoline
2 Stars from 2 Votes
5068 Downloads
12 cu.m. Skip
12 cu.m. Skip
I needed a model of a skip and could not find one. Created this from data obtained on the net. Not perfect, but does the trick and shows intent.
2821 Downloads
18' Coniferous tree
18' Coniferous tree
Sample coniferous tree from Jeff Rath's collection at http://www.3dentourage.com made from a dwg file. Updated to work with mental ray rendering engine.
https://www.facebook.com/3dentourage/?fref=ts
4 Stars from 4 Votes
24309 Downloads
1800x1800 trellis fence
I built this to get in a planners face! garden trellis, not adjustable, didnt see the need for it?
4.5 Stars from 4 Votes
Product Version: Revit MEP 2012
20239 Downloads
Page generation time: 0.2041
