Objects
Page 1 of 146 | 1 | 2 | 3 | 4 | 5 Next >>
'Pembroke' Table
'Pembroke' Table
parametric table
3.5 Stars from 2 Votes
6321 Downloads
**UPDATED** [SMEG] - 50's Retro Style Aesthetic
Product Version: Unknown
1782 Downloads
*UPDATE* MODERN GLASS TABLE WITH CHAIRS
GLASS TABLES WITH CHAIRS
3.5 Stars from 49 Votes
132801 Downloads
012
012
http://www.revitobj.com/
http://www.revitobject.ir/
6475 Downloads
01813 Lolita Armless - David Edward
First, thanks to revity city user @clars for uploading this and I used it to modify to armless model in David Edwards 'Lolita' collection. Dimensions pretty much match with original but not parametric. The model has two fabric texture. Modify as needed !!!
21613 Downloads
1 Seat Sofa
1 Seat Sofa
1 Seat Sofa
3 Stars from 12 Votes
40425 Downloads
1, 2 & 3 Seater
1, 2 & 3 Seater
Generic sofa with parametised width and depth etc. Has types already created within the family in order to control the visibilty of either 1, 2 or 3 seater sofa
1.5 Stars from 3 Votes
12063 Downloads
1,2,3 or 4 seats couch
You enter just the width and Revit calculates the number of places and draw  the seat marks. Based on gordvan contribution.
6550 Downloads
4 Stars from 18 Votes
38754 Downloads
10 Simple Chair 3D
10 Simple Chair 3D
Made from 20 mm extrusion with model lines for legs and backrest. Simple chair perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
2.5 Stars from 3 Votes
2683 Downloads
10tons bollard
10tons bollard
1068 Downloads
10x15x10 basic cabana
Basic Pool Cabana
3 Stars from 2 Votes
6414 Downloads
11 67 43 - Billiard Table
Parametric. Types include Standard 7'-0", Standard 8'-0", Oversized 8'-0", Standard 9'-0", and Snooker.  (A revised version of another file on Revit City)
4 Stars from 6 Votes
22688 Downloads
11 Simple Chair 2D
11 Simple Chair 2D
True 2D Metric Mass chair made from flat surfaces and lines. Simple chair perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
11511 Downloads
11' Locker Room Bench
2970 Downloads
12 Seaters Conference table
W488*D122 cm
built in with wire management
3.5 Stars from 15 Votes
38732 Downloads
12 Simple Table 2D
12 Simple Table 2D
True 2D Metric Mass table made from flat surfaces and lines. Simple table perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
3551 Downloads
123_or_4_seats_couch_4553.rfa
4747 Downloads
13 Simple Stool 2D
13 Simple Stool 2D
True 2D Metric Mass stool made from flat surfaces and lines. Simple stppö perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
1383 Downloads
14 Simple Sofa 3D
14 Simple Sofa 3D
Simple sofa made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
4 Stars from 2 Votes
2550 Downloads
1500wide x 2000m double bed
3.5 Stars from 11 Votes
18087 Downloads
16" FACE OUTS
16" FACE OUTS
16" FACE OUTS
1 Stars from 1 Votes
2097 Downloads
17 Simple Table 2D
17 Simple Table 2D
Simple table made from an flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface.
2136 Downloads
18 Simple Armchair 3D
Simple armchair made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface.
1985 Downloads
19 Simple Shelf 2D
19 Simple Shelf 2D
Simple shelf made from flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
2 Stars from 1 Votes
5179 Downloads
1Wardrobe
1Wardrobe
4 Stars from 15 Votes
49398 Downloads
2 Draw Fully Parametric Filing Cabinet
Visit http://www.urbimrevitcomponents.co.uk/ for access to more free downloadable Revit Components.
Also follow us on Facebook http://goo.gl/xDWne to keep up to date with the latest Revit Component uploads.
urBIM Revit Components
12715 Downloads
2 person rounded desk
Approximately 6' wide, 2.5' deep, height can be adjusted
3006 Downloads
2 Seat computer desk
4 Stars from 8 Votes
36057 Downloads
2'-6" x 3'-0" Photo Frame
2'-6" x 3'-0" Photo Frame with editable Material.
Product Version: Revit Architecture 2019
855 Downloads
Page generation time: 0.4346
