Arched Window with Parametric Brick Arch
22372 Downloads
4.5 Stars from 7 Votes
A window with a fully parametric brick arch.  This took quite a while to figure out, but I wanted to share it with anyone that wanted it.  The brick arch is fully parametric in that it will adapt to the width, height, or arch height of the window.  The number of bricks will also adapt depending on how wide/tall the window is.  The window itself can be adapted as needed.  Note.  This arch part of the window is made to be configured by the height of the arch, not by a radius.  I did this since I wanted to be able to specify a specific height for the arch to match brick coursing.   And of course feel free to change the window to an opening/door/whatever.  Just make sure you keep the main parameters.
CSI Division: 08 50 00 Windows
RevitCity Division: Windows
Uploaded By: themacguy
Uploaded On: Fri, Oct 17, 2008
Original Creator: themacguy
Wed, Nov 19, 2008 at 2:04:38 PM
RainaMc
RainaMc Avatar
Joined Mon, Sep 8, 2008
It looks great I would love to be able to use the window as I am new and not skilled enough yet to make something like this.  However I work in 2008.  Is there any way this can be saved down to 2008?
Thu, Oct 14, 2010 at 7:05:30 PM
stankywilliams
Joined Sun, Oct 3, 2010
love it-- any way you can give a brief step by step of how you did it?
Sat, Dec 18, 2010 at 2:44:27 PM
cvee
Joined Tue, Sep 21, 2010
how do i cut a arch in a cricle
Sat, Dec 18, 2010 at 2:45:25 PM
cvee
can i get a answer please iuse 2009
Tue, Apr 19, 2011 at 3:42:52 AM
galen
Joined Wed, Feb 23, 2011
1 Stars from 1 Votes
Quite nice for brick facades. Wish that the number of mulliens was parametric.
Wed, Feb 8, 2012 at 6:10:05 AM
Viktoria
Joined Thu, Nov 24, 2011
Thanks a million!
Thu, Sep 13, 2012 at 10:59:40 AM
giago
Joined Wed, Sep 12, 2012
grazie
Thu, Jul 18, 2013 at 11:25:56 AM
brancampbell01
Joined Thu, Jun 21, 2012
BEAUTIFUL!! THANK YOU!!
Thu, Jul 18, 2013 at 12:56:24 PM
brancampbell01
Sat, Jun 6, 2015 at 12:51:54 PM
riarchitect2012
riarchitect2012 Avatar
Joined Tue, May 8, 2012
4.5 Stars from 25 Votes
thank you >>>It seems usefull
even if we are in 2015!
Mon, Jun 29, 2015 at 11:23:03 AM
rdpowell18
Joined Thu, Dec 4, 2014
I am struggling to change the width of the opening so that the arch width will change along with it. What is the proper way to do this?
Mon, Jun 29, 2015 at 11:35:23 AM
rdpowell18
Mon, Oct 8, 2018 at 2:45:49 PM
#13
pashst
Joined Sat, Sep 8, 2018
3 Stars from 7 Votes
Thank you, very nice.
Fri, Jul 14, 2023 at 5:21:09 AM
#14
maze999
Joined Mon, Jun 12, 2023
Really like the post Can Hedgehogs Eat Chocolate all related information here.
Mon, Oct 16, 2023 at 7:18:21 AM
#15
bekeane
Joined Mon, Oct 16, 2023
Sharing such designs with the community can be a great way to contribute to the design and architectural Pokedoku field, and it may help others save time and effort when creating similar elements for their projects. If you have any questions or need assistance with anything related to your design, feel free to ask
Wed, Jul 17, 2024 at 12:22:29 PM
#16
PollyTomlinson
Joined Fri, Jul 12, 2024
The ability for the brick arch to adapt to changes in width, height, and arch height of the window is a significant advantage. It ensures that the design can be easily customized to fit various architectural needs without extensive manual heardle unlimited adjustments.
Fri, Apr 10, 2026 at 9:29:37 AM
#17
wifaki5228
Joined Fri, Mar 22, 2024
After using the rose toy for a while, I can say it’s reliable and consistent every time, which makes it worth it.
Page generation time: 0.7630
