Pool- 6 Lane, 75' lap pool
16218 Downloads
Lap pool 75'2" long, 42' wide to accomodate 6 lanes. 9 foot deep-end, steeply slopes to 6 ' deep, then slowly slopes up to 3' deep shallow end. I've made the concrete walls for a pool of the above dimensions. Capped it with an Aluminum gutter. And filled the pool with the correct mass of water. Beware the water might not show up in your standard views becuase "mass" objects and families generally are hidden (thus you will need to tweak your visual settings, or unhide>category>mass). Also be sure to create your site around the pool extents, or excavate the necessary hole for placing the pool. If you simply put the pool on a pre-made site the site won't recognize the walls as retention and you will appear to have a pool full of dirt. |
CSI Division: 99 Uncategorized RevitCity Division: Uncategorized
Uploaded By: Drecoll
Uploaded On: Tue, Dec 4, 2007 Original Creator: Dan Drecoll
Wed, Nov 16, 2011 at 5:29:40 AM
Joined Sat, Oct 1, 2011
the water wont show up. i already did what you said. i changed the visibility/graphics settings and still no water. what should i do?
Thu, Oct 24, 2013 at 10:50:26 PM
Joined Thu, Oct 17, 2013
Thu, Oct 24, 2013 at 10:50:37 PM
Wed, Feb 11, 2015 at 10:41:34 AM
Joined Wed, Sep 10, 2014 No rating This user is offline |
hello
Wed, Feb 25, 2015 at 10:53:06 PM
Joined Mon, Dec 2, 2013
hi
Fri, Apr 28, 2023 at 10:13:25 AM
Joined Fri, Mar 24, 2023 No rating This user is offline |
hi!
Fri, Apr 28, 2023 at 10:13:53 AM
hi!
Fri, Apr 28, 2023 at 10:13:58 AM
hi!
