Pre-Engineered Metal Building Frame
3594 Downloads
This is a more or less parametric PEMB frame. Most dimensions are changeable. I was having inconsistent unit errors so to change the slope you have to change the decimal in the slope equation and the width at the top is governed by the factor in it's equation that is based on the base width. Play with it and have fun.
CSI Division: 05 12 00 Structural Steel Framing
RevitCity Division: Structural
Product Version: Revit Building 9.1
Uploaded By: Jh8man
Uploaded On: Wed, Mar 14, 2007
Original Creator: James Haliburton
Tue, Dec 28, 2010 at 10:59:32 AM
pchan
pchan Avatar
Joined Wed, Mar 5, 2008
5 Stars from 5 Votes
Slope is not parametric, it breaks when I tried to flex it
Tue, Jul 7, 2015 at 1:11:04 PM
clarkmd
Joined Wed, May 23, 2012
This works great! I had to change the decimal in the Slope equation like Jh8man said, but I also had to change the bent slope as well, for the entire family to slope correctly.  Thanks!
Wed, May 11, 2016 at 8:01:27 AM
mattpalan103
Joined Fri, Dec 6, 2013
Can someone post some instruction on how to fix the slope? Please?
Page generation time: 3.3703
