Ladder-Wall-Mounted
20360 Downloads
1.5 Stars from 10 Votes
Ladder-Wall-Mounted
Ladder-Wall-Mounted - Adjustable Height
CSI Division: 14 30 00 Escalators & Moving Walks
RevitCity Division: Stair Components
Uploaded By: markitekt
Uploaded On: Mon, Sep 11, 2006
Original Creator: markitekt
Fri, Dec 1, 2006 at 1:31:02 AM
renee
Joined Mon, Jun 28, 2004
Height is marginally adjustable- the supports don't adjust accordingly. Width is not adjustable.
Thu, Jun 10, 2010 at 5:22:45 PM
jhmorris5
Joined Mon, Sep 25, 2006
Crashes revit 2010 when I try to load the family.
Thu, Dec 9, 2010 at 2:41:00 PM
geethomps
Joined Thu, Oct 25, 2007
I had a 2010 crash trying to use this family. It also hangs up Windows 7.
Tue, Feb 25, 2014 at 1:20:55 PM
markitekt
Joined Mon, Apr 25, 2005
It was intended to only be vertically adjustable.  The cage configuration was never intended to be adjustable.
Tue, Feb 25, 2014 at 1:26:01 PM
markitekt
Actually, This one should work for 20-foot heights and shorter.  Above that most building codes require the addition of a safety cage.  I uploaded a different family with a safety cage and adjustable in height.
Wed, Apr 26, 2017 at 1:22:19 PM
nathanhalimi
Joined Wed, Feb 3, 2016
Not parametric. Rungs do not array properly.
Page generation time: 0.6272
