34 Users Online (32 Members):
SIMES S.p.A. - MINISTAGE SPOT LIGHT - outdoor lighting fixtures
2375 Downloads
MINISTAGE ROUND SPOT
Art. S.1315W1 MODULES COB 3000K 220-240Vac 1225lm CRI 90 MacAdam step 3Rated luminaire luminous flux: 1040lmRated input power: 11.2WLuminaire efficacy: 93lm/WElectronic ballast ON/OFF not dimmable CELUMINAIRE TYPEProjector. IP rating IP 66MATERIAL CHARACTERISTICSDie-cast EN AB-47100 aluminium housing with high corrosion resistance.Stone wash surface treatment prior to painting process. A4 grade Stainless Steel screws with 2,5-3% molybdenum content which increases the resistance against corrosion. Silicone gaskets. Painting Process : 3 Step Process1) Surface treatment with BONDERITE. A heavy metal free chemical surface treatment containing ceramic nano particles giving a cohesive, inorganic and highly dense protective coating. 2) PRE POLYMERIZATION a process of introducing an epoxy primer with excellent characteristics to the paint which also offers very high resistance to oxidation due to its Zinc content. 3) POLYMERIZATION a process with the application of polyester powder with high resistance against UV rays and harsh weather conditions. Resistance test protection for Marine applications for 1200h. Mechanical resistance IK 07LIGHTING PERFORMANCE99.98% pure aluminium reflectors, or with concentrating lenses: The sophisticated optics focuses the beam and makes the light comfortable by reducing the direct glare of the light source. Clear toughened glass. LOR -- INSTALLATION AND MAINTENANCEThe tempered front glass diffuser is fixed externally to the fitting through silicon resin, perfectly flush with the front ring. Water and dirt deposits that can disturb the lighting performance of the projector can easily flow away. WIRINGSupply 5m cable section type FEP/FEP + PCP (Microstage and Ministage) or FLAT (Stage and Megastage) sealed with B component epoxy resin, wired internally protected by silicon sheaths. Isolation: CLASS II . Available colours: Aluminium grey (cod.14), Anthracite grey (cod.24). Weight: 1.73 Kg Glow Wire test: --LED circuit included.REGISTERED DESIGN MICROSTAGE BLADE OF LIGHT PATENTED, REGISTERED DESIGNThis luminaire contains built-in LED modules. In case of damage or malfunction please contact the manufacturer to receive additional instructions on how to replace and relative spare parts to order. The LED modules cannot be handled in the luminaire by the end user.LED modules are engineered accordingly to the existing regulations of Lumen Maintenance (LM80) and Technical Memorandum (TM21), where uniformity and quality of the light is 70,000 hours referred to L80 B10 Ta 25 ° C (50,000 hours referable to L80 B10 Ta 40°C). Lifespan of the luminaire > 50,000 hours at 40°C. Performance Ambient temperature Tq 25°C. Operating ambient temperature range is from -20°C to +50°C. Storage temperature range from -20°C to +60°C. |
CSI Division: 26 56 00 Exterior Lighting RevitCity Division: Electrical > Lighting > Exterior
Product Version: Revit Architecture 2018 |
Uploaded By: SIMES
Uploaded On: Thu, Nov 25, 2021 Original Creator: SIMES S.p.A.
