SIMES S.p.A. - BLINKER - wall recessed outdoor lighting fixtures
263 Downloads
BLINKER
Art. S.6080W 1 MODULES COB 3000K  220-240Vac 2419lm CRI 90 MacAdam step 3Rated luminaire luminous flux: 567lmRated input power: 23WLuminaire efficacy: 25lm/WElectronic ballast  ON/OFF not dimmable CELUMINAIRE TYPEWall mounted luminaire. IP rating IP 65MATERIAL CHARACTERISTICSAluminium die cast housing in EN AB-47100 (low copper content) with high resistance against corrosion. Stone wash surface treatment prior to painting process. A4 grade Stainless Steel screws with 2,5-3% molybdenum content which increases the resistance against corrosion. Silicone gaskets. Painting Process : 3 Step Process1) Surface treatment with BONDERITE. A heavy metal free chemical surface treatment containing ceramic nano particles giving a cohesive, inorganic and highly dense protective coating. 2) PRE POLYMERIZATION a process of introducing an epoxy primer with excellent characteristics to the paint which also offers very high resistance to oxidation due to its Zinc content. 3) POLYMERIZATION a process with the application of polyester powder with high resistance against UV rays and harsh weather conditions. Resistance test protection for Marine applications for 1200h. Mechanical resistance IK 06LIGHTING PERFORMANCEReflector in 99.98% pure anodized aluminium . Acid-etched toughened glass 4 mm thick. LOR -- INSTALLATION AND MAINTENANCEThe recessing box is provided with support ribs that make it crush-proof during installation; the ribs are molded to the recessing box and cannot fall out before installation. The ribs must be removed before the installation of the luminaire. The lamp body is secured to the recessing box through stainless steel clips; the electric components are protected by a covering reflector that houses the light source. WIRINGSingle cable entry . Isolation: CLASS I . Available colours: Aluminium grey (cod.14). Weight: 3.28 Kg Glow Wire test: --LED circuit included.BLINKER REGISTERED DESIGNThis luminaire contains built-in LED modules. In case of damage or malfunction please contact the manufacturer to receive additional instructions on how to replace and relative spare parts to order. The LED modules cannot be handled in the luminaire by the end user.LED modules are engineered accordingly to the existing regulations of Lumen Maintenance (LM80) and Technical Memorandum (TM21), where uniformity and quality of the light is 70,000 hours referred to L80 B10 Ta 25 ° C (50,000 hours referable to L80 B10 Ta 40°C). Lifespan of the luminaire > 50,000 hours at 40°C. Performance Ambient temperature Tq 25°C. Operating ambient temperature range is from -20°C to +50°C. Storage temperature range from -20°C to +60°C.
CSI Division: 26 56 00 Exterior Lighting
RevitCity Division: Electrical > Lighting > Exterior
Uploaded By: SIMES
Uploaded On: Wed, Nov 24, 2021
Original Creator: SIMES S.p.a.
Page generation time: 0.0254
