6" Equilateral triangle Model pattern
2304 Downloads
6" Equilateral triangle .pat file can be used in revit and other supported software.
How to use in revit
1.Copy the text. open note pad. Paste it and save with .pat(dot pat) extension
2. Open material tab then surface pattern then model pattern-- New--load the pat.
CSI Division: 09 60 00 Flooring
RevitCity Division: Fill Patterns
Uploaded By: Kalaig
Uploaded On: Sun, Jul 11, 2021
Original Creator: Kalaignanam Dhanabalan
Wed, Dec 31, 2025 at 6:12:37 PM
hahoto6818
Joined Wed, Dec 31, 2025
Below you will understand what is important, the idea provides one of the links with an exciting site: Tampa Pest Control
Wed, Dec 31, 2025 at 6:17:42 PM
hahoto6818
Cool you inscribe, the info is really salubrious further fascinating, I will give you a connect to my scene.  Orlando Termite Treatment
Sat, Jan 3, 2026 at 10:48:49 AM
hahoto6818
You ought to basically fantastic not to mention solid advice, which means notice: Kissimmee Bed Bug Treatment
Sat, Apr 18, 2026 at 10:14:09 AM
EmmaRobert
Joined Mon, Mar 17, 2025
Every decision in survival race could mean victory or instant elimination.
Page generation time: 0.1064
