Door-Adjustable
14219 Downloads
4 Stars from 6 Votes
Door-Adjustable
A great door for space planning, early design, existing conditions, & tracing 2D CAD dwgs.
ELIMINATES THE NEED FOR DOZENS OF DOORS!
Features:
Frame automatically adjusts to wall thickness
Adjustable door swing angle
Adjustable door thickness
Adjustable width / height
width adjustments can be done with the align tool!
width & height show up on schedule
All parameters are "instance parameters" which cuts down on the need to have dozens of doors in your project.
CSI Division: 08 Openings
RevitCity Division: Doors & Openings
Uploaded By: jontramos
Uploaded On: Thu, Sep 1, 2005
Original Creator: Jon Ramos
Fri, Aug 25, 2006 at 8:40:48 AM
Pyxis55
Joined Mon, Dec 1, 2003
I'm using this door in design development of a curved apartment building with many angled walls. It works perfectly! This solves one of my big frustrations...
Fri, Aug 28, 2009 at 9:58:10 AM
dfitzladdy
Joined Tue, May 27, 2008
5 Stars from 3 Votes
ALMOST perfect.  i changed the trim from 3" to 2", and all but one sides changed. any idea how to fix this??
Thu, Dec 16, 2010 at 5:55:13 AM
mikeap911
Joined Tue, Nov 23, 2010
I tried to change the swing of this door to 0 degrees and 180 degrees, and neither worked.
Tue, Apr 19, 2011 at 11:50:33 AM
Hawkmoon36
Joined Thu, Jul 24, 2008
Swing option does not work.
Wed, May 25, 2011 at 1:00:31 PM
duncanidaho
Joined Thu, Jul 17, 2008
You have a great work. Congratulations.
I need change the units to the european system but I supouse that I haven`t any problem.
Tue, Jun 14, 2011 at 8:56:01 AM
Koch2000
Joined Thu, Feb 17, 2005
Nice door but the swing angle parameter doesn´t work Congratulatiobs
Tue, May 29, 2012 at 9:40:47 AM
JessKaadou
Joined Wed, Feb 24, 2010
ANY IDEA WHY THE SWING ADJUSTMENT DOES NOT WORK? THAT WAS THE ENTIRE REASON FOR DOWNLOADING...
Mon, Mar 23, 2015 at 12:50:07 PM
Kpriest
Joined Fri, Jan 9, 2015
Can you make it so you can change the swing? We use 45 degrees a lot.
Thank You
Mon, Sep 26, 2016 at 8:39:38 AM
SeanWithe
Joined Mon, Sep 26, 2016
Downloaded for the adjustable feature. Double door works perfect but when I try to edit the width and height on the single door it just distorts and adds a massive door frame. Any help?
Page generation time: 0.4398
